311 Engine Upgrades
#233
I’ve been really busy over the last couple days. I saw your post here and was reminded to get back to you. Sent you a text.
We’ll see about who gets in first. I’m not rushing anything at this point.
I also need to figure out issues on the Cig. We fixed a bunch of fuel issues, new fuel pump, and had to replace the power steering pump (front seal took a dump). All of the carb linkage binds against fuel lines so that’s got to be sorted out too. And the MSDs won’t fire so not sure what that’s all about (power shorts to ground). F’ing boats. Lol
#234
#235
Well that was a pain! The first one anyway.
I was hoping to be able to get one in mostly dressed but that wasn’t going to work. In the end everything on the front had to come off. Nothing like having to do a bunch of work twice.
It had been a while since I’d had everything apart so it took some time to trust the stack of the washers at the transom/transmission. Fortunately, Rookie confirmed that I had it right. It took a lot of trying to get everything lined up but once we figured it out, it went easy. The second engine took all of a half hour to get in bolted up.
I’ll probably have her running by the end of the weekend. Can’t wait!
Some pics…
Prep the day before. Virginia Beach has an ordinance that prohibits having trailers in driveways. Had to get it all done before someone complained.
Nice and clean with fresh paint. When it’s wet, it’s a skating rink. Ask me how I know. Don’t mind those blue butt connectors. I have a new weather pack connection ready to replace that.
Getting there!
Some pics…
Getting there!
#236
Some pics…
Getting there!
Some pics…
Getting there!
#238
Closer. The new hard-wall hoses are making it a total ***** to get the raw water pumps back in. I also have some slight exhaust alignment issues with the AFR heads but should be okay.
Nice to have some power and music playing while working.
Once I’m sure that all my fuel fittings are leak-free, I’ll put the port engine’s exhaust on.
I also ordered my Innovate DLG-1 wideband. I need to do some gauge moving to fit it.
- fuel gauge will move to hour meter slot.
- hour meters will be in the bilge with their respective engine.
- volt meters will be combined into one with a toggle to check charging (not sure where it’s going, maybe depth finder hole and take depth readings from GPS?).
- oil temp gauges will go where the volt meters used to live.
I need to do some paint touch-up. This was taken Sunday night. I’ve gotten a lot farther than what’s here.
#239
Tom for your slight exhaust alignment issues try looking into these, Shields Hump Connectors, they also make a double.
Shields 220S Series, Silicon Hump Hose Connector, Molded Silicone (go2marine.com)
Boat is looking good.
