New project......replacing TV in a 382. >
Old 01-04-2007 | 05:54 PM
WAGS382's Avatar
Default Re: New project......replacing TV in a 382.
I am not sure how to get the tv out, but I think I know how the tape got jammed.
Jeff
WAGS382 is offline
Old 01-04-2007 | 08:41 PM
t500hps's Avatar
21 and 42 footers
Jeff
Who the he11 was watching TV in during THAT ride!!!!
t500hps is offline
Old 01-05-2007 | 03:51 PM
masi242's Avatar
Just buy a new 382, your due for something new
masi242 is offline
Old 01-05-2007 | 07:53 PM
PhantomChaos's Avatar
LOL.....the new one's aren't as good as the 2001 model? That's just what I heard......
PhantomChaos is offline
Old 01-05-2007 | 07:54 PM
Jeff
Nope....that is what we had to do to get the tape un-jammed!! Until that moment, we had tried everything, but this jump worked like a charm! Boink!
Old 10-29-2008 | 07:33 AM
Default TV upgrades
What are u guys using for power inverters ?? Any extra batteries, how many. Looking to install a 13'' flat scren in my 27sr1 (mounted by the sink)
pocketchange22 is offline
Old 10-29-2008 | 11:37 AM
C_Spray's Avatar
Diamond Member #001
The TV/DVD unit I found uses a 12 volts. It came with a lighter plug and a wall transformer. I just cannibalized the power cord from the lighter plug.
If you do go with a 110vac unit and need to use an inverter, you will probably need at least a "modified sine wave" type, if not a "true sine wave" unit. Cheap square wave inverters are likely to wreack havoc on anything electronic. I would think that a couple hundred watts would be enough. Check you TV specs and go at least twice what it says the current draw is. (Watts = volts x amps.)
Found pictures of my busted TV and the finished TV/DVD conversion. (And YES - I did clean up the wiring behind the TV!!!
Attached Thumbnails New project......replacing TV in a 382.-bustedtv-large-.jpg   New project......replacing TV in a 382.-p1000397.jpg   New project......replacing TV in a 382.-p1000393.jpg
C_Spray is offline
Old 10-29-2008 | 04:23 PM
Default TV 's
Just curious, how long does your battery last for w/ the tv on??
I am going to run a 1500 watt inverter, have a 160amp alternator and an isolator to constantly charge the 3rd battery. Have the battery, and isolator mounted, have to get my a$$ together and buy a tv.
Your set up looks very clean, nice job.
Old 10-30-2008 | 12:39 PM
C_Spray's Avatar
Diamond Member #001
Thanks for the compliment - It took a LOT of hard work, including bandsaws, milling machines, and more. That was just for the acrylic ("plexiglas") part. You don't want to know how much work the polished stainless housing was....
I have two Group 31 combination deep cycle/starting batteries for the starboard engine and house power. TV's draw so little current, I would expect it to last about 3 days before drawing those babies down! Since I can combine the two banks of batteries if need be, I don't worry too much about draining the house bank down. That's also why I use combination deep cycle/starting batteries. If you drain a starting battery really low, you'll cause permanent damage.
Bear in mind that there is also a slight voltage drop through the diodes in an isolator, so your batteries will always be a couple of tenths of a volt lower. You can use a combiner instead - They usually cost more, though.
C_Spray is offline
C_Spray
02-07-2012 05:00 PM
AGGRAVATION28
Do It Yourself, Boating on a Budget
3
06-21-2008 07:28 AM
Maritime_Eng
12-26-2005 05:09 PM
Wateronthebrain
09-14-2004 07:37 PM
