"Thru Hulls" are OFF >
Old 10-24-2004 | 06:41 PM
Formula Outlaw's Avatar
Default "Thru Hulls" are OFF
Got the four original thru hulls off this afternoon. Went quite easily actually. I used the "giant" Craftsman flat blade screwdriver and gently inserted it between the flange and the fiberglass where the "goo" was gooiest. Then took a block of wood and gently pried away from the transom. Then did the opposite side. Once I got it away about three sixteenths of an inch, I put a flatbar on each side again prying against a block of wood and pried outward. Once I had reached the end of the flatbar length, I used a four ft. piece of strapping and did all the way around, again, against the block of wood. They came out pretty easy. Took about eight minutes per unit. Tomorrow the new exhaust is going and awaiting the arrival of the brackets for the shifters, oil filters, and electronics and the new tips.
Also need two new batteries.
Formula Outlaw is offline
Old 10-24-2004 | 08:47 PM
offthefront's Avatar
Default Re: "Thru Hulls" are OFF
who you gettin the brackets and tips from ?
offthefront is offline
Old 10-24-2004 | 10:36 PM
Am getting Stainless Marine tips from Too Old with the internal flappers, that don't make any noise and don't burn out.
Eddie Marine is sending me the brackets, at no charge I might add.
And, of course, NO MORE DEAD WEIGHT MUFFLER BOX......
fountainfevr
Fountain
15
03-04-2007 05:05 AM
electrical1
11
11-09-2006 08:51 AM
Formula Outlaw
10-19-2004 05:19 PM
Formula Outlaw
10-11-2004 09:23 PM
mikesufka
12-26-2002 11:23 AM
