The complete 272 thread >
Old 10-03-2005 | 05:21 PM
  #31
mopower's Avatar
Toxic FORMULA
Default Re: The complete 272 thread
Most I've seen are 454s. There is one with 350s at the marina where I launch. I think you would be hard pressed to get 60 mph out of 350s , but a lot more room in the engine comp. to work on them. I don't believe they were offered with 365hp only 330s. 292s had 365 Mags optional.
mopower is offline
Old 10-04-2005 | 10:55 AM
  #32
mtgbiker's Avatar
Originally Posted by mopower
You won't be able to tilt all the way up as center mounted steering rams will hit the center pod of the ST. I have K-planes and no room to mount the rams outside the drives.
What about installing internal shims(stops) on the Trim Cylinders? This would limit total travel right?
mtgbiker is offline
Old 10-04-2005 | 07:28 PM
  #33
mopower's Avatar
Toxic FORMULA
Well , the tilt limit also varies if the drives are straight(greatest tilt) or if they are turned slightly(the least tilt room available)
Here's some pics from another 272 hyd.steering install
Attached Thumbnails The complete 272 thread-holes-medium-.jpg   The complete 272 thread-installxs-medium-.jpg   The complete 272 thread-closetotop-medium-.jpg
mopower is offline
Old 10-04-2005 | 09:36 PM
  #34
mopower's Avatar
Toxic FORMULA
Close...real close
Attached Thumbnails The complete 272 thread-1d.jpg   The complete 272 thread-1e.jpg
mopower is offline
Old 10-08-2005 | 09:59 AM
  #35
32storm's Avatar
Originally Posted by Clay Avedisian
Thinking about a 272, '88-89. Trying to get back into boating and had an '84 242. Any problems to look for, rotten transoms or stringers? I had 350/260 alphas but the 272 was offered with 454/330/365 bravos. There are both combos out there for sale, any feedback on both? Clay
The 454 mags were available on '91. they weren't available on '88 & '89's.The early dealer info from july '89 doesn't list the Mag as an option either in '90, only the 7.4 w/Bravo's & 350 mags w/Alpha's. I don't know if it was available later in the model year.
32storm is offline
Old 10-12-2005 | 09:04 PM
  #36
mtgbiker's Avatar
Has anyone installed a set of CMI e-Top headers in a
272-SR1?
mtgbiker is offline
Old 04-13-2006 | 01:36 PM
  #37
mtgbiker's Avatar
Hey Mopower or Opie 272!
Do you guys know what the length of the drive indicator cables are for the drives?
The morse 33c cables in the boat don't have the any numbers stamped on the red jacket. I figured one of you two have probably replaced them.
mtgbiker is offline
Old 04-13-2006 | 04:47 PM
  #38
mopower's Avatar
Toxic FORMULA
Not off hand but I did replace mine 2 years ago. All I did was call Formulas tech line with my HIN # and they told me exactly what I needed. Talk about service after the sale...how about 17 years after
mopower is offline
Old 04-13-2006 | 06:32 PM
  #39
mtgbiker's Avatar
Mopower,
Thanks for the tip. I just got off the phone with tech support at Formula. The correct lengths are 21' and 22' for the drive indicators. and 18'/23' for the K-Planes.
The motors dynoed at 525 and 522hp. The XS Marine steering is installed, the new dash and Livorsi gauges are almost finished and the second motor will be fully rigged by Saturday. I also removed the k-planes and powdercoated them black. What a bioche to remove!
Last on the list is installing the new indicator cables then installing the Motors, drives and steering rams.
I hope to splash her week after next. By the way, are you running Bravo 1's , Hydromotives or another brand prop?
mtgbiker is offline
Old 04-13-2006 | 09:20 PM
  #40
mopower's Avatar
Toxic FORMULA
B1's.
Sounds like you've been pretty busy with yours too
mopower is offline
