Formula Dash Panels >
Formula Dash Panels
Formula Dash Panels
Old 09-27-2010 | 09:43 PM
  #131
I am lookiing to rework my 199 353 panel to allow for a Garmin 546 flush mount which requires an open spot of about 6 3/4 X 7. Luckily I only have 6 small gauges and 3 large ones. I just emailed Paneltronics who apparently does the factory panels for Formula. Any suggestions on other fabricators?
Joe308 is offline
Old 09-28-2010 | 08:50 AM
  #132
mroberts's Avatar
Livorsi?
mroberts is offline
Old 11-01-2011 | 02:59 PM
  #133
Looking at buying a 1997 382.. quick question.
I plan on using the stock panel and having it hydo dipped ion a carbon fiber pattern. and then new gauges. can you install new gauges int he factory holes? as the hole look to have the factory gauges BEHIND the panel....
also I want to do the flush mount GPS unit. so I may have to remake a panel as well.
mittens is offline
Old 11-01-2011 | 03:09 PM
  #134
offthefront's Avatar
those year panels .... IMO suck ....upgrade to the newer look ....it will only cost the price of the new panels .....will look alot better ......m
offthefront is offline
Old 11-01-2011 | 04:02 PM
  #135
PhantomChaos's Avatar
1997 had VDO gauges and yes they mount behind the panel. Get a new panel.
PhantomChaos is offline
Old 11-02-2011 | 09:53 AM
  #136
The dash panel woul dbe covered in carbon fiber look (to kind of update, and matcht eh black fiberglass) with new gauges.
or are you saying i cann ot mount regular gauges in that panel? are the holes not the correct sizes?
mittens is offline
Old 11-02-2011 | 11:56 AM
  #137
I don't remember.......but if you have a ruler, measure the holes! The thing is as I remember, the panel for the VDO gauges has studs pressed into the panel to mount hte gauges so those would have to be cut off even if the gauge holes are the right size. Can't be that big of a deal. Just measure the holes.
Old 11-02-2011 | 03:06 PM
  #138
WEll you said get a new pannel. and from what i have read a new one from Formula is rediculous $$$ and most have made aluminum ones. but there are not extras?
I would love to find a blank one, but no biggy on the factory holes if i can cut out the speedo and fit a GPS in there.
mittens is offline
Old 11-09-2011 | 05:22 PM
  #139
Innotech Products Inc
314-432-1900
Ask for Steve Dunning.
mkole is offline
Old 11-10-2011 | 01:55 PM
  #140
J.B. Marshall's Avatar
JB Marshall
314-432-1900
+1 Steve is awesome to work with and his work speaks for its self. I re-did my 382 dash panels last winter and Steve created all new panels.
J.B. Marshall is offline
