Formula Dash Panels >
Formula Dash Panels
Formula Dash Panels
Old 03-23-2005 | 05:26 PM
  #41
Audiofn's Avatar
Charter Member #232
Default Re: Formula Dash Panels
Also you leaving room for bezels in there?
Jon
Put your best foot forward!
Audiofn is offline
Old 03-23-2005 | 05:30 PM
  #42
dukenrock's Avatar
Check out the dual tachs. Floscan had one that I almost bought. Pretty neat because its easy to see both at the same time.
dukenrock is offline
Old 03-23-2005 | 06:20 PM
  #43
RedDog382's Avatar
Originally Posted by Audiofn
A is the best IMO however I am trying to figure out what all those guages could possibly be!!!
2 tachs
1 speedo
2 oil temps
2 oil preasures
2 water temps
2 water preasures
1 fuel guage
1 volt meter
2 engine hour meters
That got me to 12 and you still have a extra hole there.
I would get the tachs with the hour meter in them and then you can take out some more guages.
Jon
These are already standard issue in the newer Formulas!
RedDog382 is offline
Old 03-23-2005 | 10:28 PM
  #44
PhantomChaos's Avatar
2 tachs
1 speedo
2 oil temps
2 oil pressure
2 water temps
2 water pressure
1 fuel guage
1 volt meter
I would get the tachs with the hour meter in them and then you can take out some more guages. OR hide the engine hour guages and the volt and fuel guage and make it easier to read. I would also suggest that you put your guages together. IE. port and starboard oil preasure together. That way you can just scan the dash and look at them to see if they are pointing in the same direction, not actually have to read them. That is how all the race boats are set up.
Jon
I'm leaning toward B or D personally. You need to learn how to count Jon!!! I added your list and got 15. Here's teh deal.....
2 tachs/hr meters (BIG)
1 speedo (BIG)
2 oil temp
2 water temp
2 oil pressure
2 water pressure
1 fuel guage
2 volt meter
1 GPS
something else too.....can't remember what at the moment.
PhantomChaos is offline
Old 03-23-2005 | 10:36 PM
  #45
Better leave room for those Boost gauges... You never know!!
KL
CAFormula1 is offline
Old 03-23-2005 | 10:51 PM
  #46
Poorsche's Avatar
Several manufacturers have dual tachs--I put a Gaffrig/Livorsi sync guage between tachs.
As my son says--"at my age"--- I can't hear if engines are synched or not--so it has some value in that it make him think I really pay attention to what he complains about on MY boat.
Poorsche is offline
Old 03-23-2005 | 11:57 PM
  #47
Jon
Yes Jon! Momma didn't raise no dumby!!!
Kev......Boost? What is that?
Old 03-23-2005 | 11:59 PM
  #48
Audiofn's Avatar
Charter Member #232
I am fairly sure you only need the one volt guage as the Formula can look at both batteries independently or together. If you run the battery switch in the both mode you will be looking at both batteries anyhow. On B were is the GPS?
Jon
Audiofn is offline
Old 03-24-2005 | 12:00 AM
  #49
Audiofn's Avatar
Charter Member #232
I know mine did not but this is you we are talking about
Audiofn is offline
Old 03-24-2005 | 12:02 AM
  #50
The GPS? In my pocket! (or over board) It's the one thing that slows down the boat!
