Big Big Problems......need Advice! >
Old 08-24-2005 | 03:47 PM
  #51
Lofty's Avatar
Default Re: Big Big Problems......need Advice!
Originally Posted by 29scarab10
Lofty,
If Dago does not take you up on your offer for the rams, I will take them as I broke a ram this weekend.
Thanks,
Allen
email or call
Fionn (finn)
925.952.4240
510.541.8124
[email protected]
Lofty is offline
Old 08-24-2005 | 04:41 PM
  #52
Dago Racing's Avatar
Originally Posted by Lofty
email or call
Fionn (finn)
925.952.4240
510.541.8124
[email protected]
WOW....VERY COOL OF YOU!!! I sent you a PM....not sure if that's what I need......if I do I would GREATLY APPRECIATE THEM.......if not thanks for the offer and the other OSO Member is more than welcome to them......VERY COOL INDEED.....you are THE MAN!!!
Dago Racing is offline
Old 08-25-2005 | 10:41 AM
  #53
fountain27ho496's Avatar
Sorry for your hell.
My battery was just drained by my bilge pump running for no reason. I replaced it.(what fun) and the new one runs hot all the time also. Anybody know why? And speaking of seats my passenger seat wont go up th last inch? Any ideas?
Hope you figure it out. JC
fountain27ho496 is offline
Old 08-25-2005 | 11:48 AM
  #54
Originally Posted by mike11
Id insure that thing to the max and drill a BIG hole in the bottom in DEEEEEP water
Ok, right about here you know its time for plan B, shine it up tow it to your local strip club, then give the valet guy a few bucks to tow you back and forth through the parking lot while you sit at the helm getting a BJ on the house. hehe
Sorry for your troubles ,to credit you, you did do enough homework to pick a fountain,, you could be dealing with all this trouble on a P.O.S.
spk1 is offline
Old 08-26-2005 | 07:44 AM
  #55
things are good for now.......still have the battery issue.....I'll get it figured out sooner or later!
Old 08-28-2005 | 07:12 PM
  #56
1stfntn's Avatar
Fountain27496ho - Bilge pump is always hot so if your battery switch is off the pump can still come on if water gets in the boat/bilge. Primarily an issue for boats that STAY in the water rather than on a hoist or on a trailer, but can also be important if you store your boat outside and your cover comes off in a storm. Sorry, not trying to hijack the thread.
1stfntn is offline
Old 08-28-2005 | 10:24 PM
  #57
Dago to find your short use one battery and remove the neg cable, put a test light between the batt terminal and cable if you have a short the light will light. A radio memory will not be enough to light the light so if it is lit you have a problem. Do this and start popping fuses and tripping breakers till the light goes out then you've found the circuit,and go from there.
mike11 is offline
Old 08-31-2005 | 08:32 AM
  #58
Good advice........I'll have to try that out!
Old 08-31-2005 | 05:44 PM
  #59
Ok Its a hi-jack, Fstftn I know its hot but my bilge pump is running non stop no water no stuck float. Replaced it and still running. I pulled the fuse. Any Ideas?
Also does the neg. battery trick work on cars. My vette developed a draw. The light is on but never went out after trying every fuse? any Ideas?
Dago get a week of trouble free yet ? I hope.
Thanks for any suggestions. JC
Old 08-31-2005 | 07:38 PM
  #60
Test light trick works on any 12 v system. does your bilge pump have a internal or external float switch?
mike11 is offline
