Third Child 29 Fountain >
Old 08-10-2022 | 09:31 AM
  #81
so what do you think it should be running ? 5200 @ 68 with that prop might be all it has, I think the limiter is set @ 5350 on that engine
Many people online state that these boats run 75-80 MPH from the factory with this prop, Some switch to a 26P to get more midrange and plane speed, but they still are able to get 74-75.
DallasBAJA is offline
Old 08-10-2022 | 09:38 AM
  #82
The boat runs great and I have no issues with it, but when people keep telling me it should go 10mph faster is makes me think there is potentially something wrong with it is all and it has me curious.
Old 08-10-2022 | 10:37 AM
  #83
F-2 Speedy's Avatar
Im not drinkin the 80 mph kool-aid............Ill see if I have the 555 plug for my scanner, what does the obd connection look like ?
F-2 Speedy is offline
Old 08-10-2022 | 11:12 AM
  #84
I dont expect this boat to go 80 either, but would be nice to see 75 at least like the others are seeing. Ill have to get you a picture of the plug when we go out to the boat tomorrow evening unless someone can post one from a 525 efi. I cannot seem to locate a good picture of one online.
Old 08-10-2022 | 11:19 AM
  #85
F-2 Speedy's Avatar
Ive got the 555 adapter for my scanner, we can scan if you want to pull it to my place, run it on the hose and check things
Old 08-10-2022 | 12:40 PM
  #86
Originally Posted by DallasBAJA
Prop is a 28P Bravo
I am able to hit about 4900-5000 without trimming the drive, once I start trimming I have seen 5200 on the gauge.
Its a Bravo XR so should be 1.50 ratio, I have not taken anything apart to confirm for sure.
I typically get on plane and without any drive trim get to 60-62 MPH. Then I will start trimming until I start shaving off speed and cant seem to get anything over 68.
That is a lot of slip even at 4900 its over 21%.
Try a good known prop would be my first try. You never know what people do to props.
Had a buddy that bought a boat and it was a POS to get on plane, we checked the props that came with it and someone had cut diameter down for whatever reason.
Wildman_grafix is offline
Old 08-10-2022 | 12:56 PM
  #87
I have a good friend that is willing to let me borrow her 27P 4 blade Power Tech prop to test. She also has a 28P labbed bravo I could try as well. Ill give this a shot.
Old 08-10-2022 | 02:14 PM
  #88
My friend had a 1998 29’ fountain with a single 500hp. The boat ran best with a 24 lh hydromotive. We routinely saw 74gps
ttuton is offline
Old 08-10-2022 | 02:52 PM
  #89
For reference 24 Hydro is like a 26 Bravo. For some reason Bravo's measure a bit less then marked.
Old 08-10-2022 | 03:01 PM
  #90
Perfect, This is getting me excited. I know this prop has a small ding in it, but nothing crazy. Ill test the 27 since it is what I have access to and go from there.
