Tunnel Ram Engines
Old 10-23-2006 | 07:50 PM
Default Re: Tunnel Ram Engines
Hey, why not tunnel ram, EFI and blowers all at once?
Seriously though, tunnel rams rule on any V-8. Height and cost are the only reasons not to use them. Take a peek at the latest sheet metal intakes for carbs if your local drag racing engine builder will let you. Some crazy stuff going on in those plenums.
Hi Dean!
tomcat is offline
Old 10-23-2006 | 08:04 PM
Kelly o that is a nice engine what tunnel ram are you using and is it a m3 or m4 pro-charger om looking to do that combo this winter on my htm it has a 598 in it right now
dennis r is offline
Old 10-23-2006 | 08:12 PM
JCPERF's Avatar
Hi Dean!
Like this HEMI
JCPERF is offline
Old 10-23-2006 | 09:02 PM
KAAMA's Avatar
GLENNS just had Wesseldyk build him a pair of 565cid engines with hyraulic roller cams, 315cc AFR CNC ported heads, 9.3 comp ratio and 34* of timing. and tunnel rams that so far on WESCO's dyno have made 700hp on the nose @5400rpm.
KAAMA is offline
Old 10-23-2006 | 09:26 PM
like that serpentine set up
open87 is offline
Old 10-23-2006 | 10:27 PM
racinfever's Avatar
Thanks guys for all the pics and comments - they have been great. I would like to hear some more on performance characteristics. Thanks in advance!
racinfever is offline
Old 10-24-2006 | 12:33 AM
Strip Poker 388's Avatar
Rob
Here's some Zul motors. Ck out the fuel injection he made .He"s been playing around with some different fuel injection stuff, he also has one with the throttle body's ,Electronic fuel injection made around 848 on pump gas.
Attached Thumbnails Tunnel Ram Engines-img_0643.jpg   Tunnel Ram Engines-zul-4-large-.jpg   Tunnel Ram Engines-zul-6-alarge-.jpg
Strip Poker 388 is offline
Old 10-24-2006 | 12:40 AM
BY U BOY's Avatar
how much low end do you lose with this set up?
BY U BOY is offline
Old 10-24-2006 | 05:53 AM
Kelly O's Avatar
It's a Holley Pro Dominator intake. M4 unit, big pulley...7psi boost. Idles and runs very well with Nickerson prepped carbs. Little rich in secondaries to be safe. 900-950hp.
Kelly O is offline
Old 10-24-2006 | 07:26 AM
Originally Posted by tripps
Yeah,all the pro-stock guys run TUNNEL RAM guess who used to run pro stock???? tripps
gee.......that would be me! Working on getting another IHRA mountain motor car assembled right now. 830 cu.in. tunnelram of course! Oh yeah Richie ran Pro Stock around the time my father did.
mrhorsepower1 is offline
