Tunnel Ram Engines
Old 10-24-2006 | 09:47 AM
Default Re: Tunnel Ram Engines
Hey Rob, many boat guys are using the Dart cast tunnel ram, but check out the long runners on that sheet metal intake. Do you know any more about that engine?
tomcat is offline
Old 10-24-2006 | 10:35 AM
Originally Posted by nocigarette
ant time you can get the fuel a liitle higher up it helps with the adomazation, i dont know if i spelled that right.............anyway,,,,,,,,,tunnel rams are great it is just that blowers have come so far in tech it is just easier to supercharge something than tune a wicked tunnel ram set up.........a blower motor is a lot easier to tune than a na motor in my opinion...............
Let me splain it for you:
It's "atomization" where the fuel droplets are made small enough by flow turbulence so they burn properly.
Tunnel rams really work well from 4000 rpm's and above (like 7000). Since most of the Marine engines top out at around 5800 or so they are not always the best choice.
Wannabe
wannabe is offline
Old 10-24-2006 | 12:42 PM
dammmagnum's Avatar
Wannabe
I think that is why Stan Pike and Inferno had problems getting up on plane sometimes. We seem to know alot more about the technology now then they did when Stan was running the set up, back in the later 70s.
Thank you
Jim
dammmagnum is offline
Old 10-24-2006 | 12:53 PM
thisistank's Avatar
My favorite.....
Attached Thumbnails Tunnel Ram Engines-zul-750.jpg   Tunnel Ram Engines-zul2.jpg
thisistank is online now
Old 10-24-2006 | 12:54 PM
Strip Poker 388's Avatar
Rob
Richie said he was just playing around with fuel injection seeing what he could do with diff set ups,A test muel. Last year when we were at PRI he ordered some throtal bodys for it then he sold the efi system off it.I think the motor was a 598,dart P1 cnc,solid roller .JC may know more?
Rob
Strip Poker 388 is offline
Old 10-24-2006 | 01:56 PM
Originally Posted by mrhorsepower1
With new cylinder head technology with higher velocity intake ports it's easy to make 700-800 HP with a single 4 barrel set up. But, with a tunnel ram coupled with these new high speed airflow cylinder heads 800 horsepower + is very achievable. I done quite a few of these setups and yes...a set of well set up carbs and the engines are dockable and very dependable as well.
What would you say if I could give you NA engines that put out 800 hp on pump gas, idle at 600 rpm, have an "economy" mode for cruising that saved you 7-10% on fuel, cost no more than a good 800 hp engine does (say 18-20k) would this interest you Mrhorsepower? Or anyone else?
Wannabe
wannabe is offline
Old 10-24-2006 | 04:46 PM
Wannabe
Wouldn't interest me at all. I build engines of my own that already have those features.
mrhorsepower1 is offline
Old 10-24-2006 | 06:37 PM
Originally Posted by Catmando
There's a drag boat(Loose Cannon I believe) that has an 813ci Ford "Mountain Motor" built by someone in Georgia. Hot boat mag ran an article on drag boats with this boat and motor mentioned. Do you know the engine builder?
most likely John Kaase. He was originally from Westlake , Ohio . My father used to do machine work for John when he was a kid.
Old 10-24-2006 | 08:14 PM
Wannabe, what are the specs on your 18k motor, cubic inch, pistons, headers,carb, etc. how many have you built and what boats are they currently in?
Buddy OO is offline
Old 10-24-2006 | 11:02 PM
2112's Avatar
Wannabe
I already have these;
8.9 to 1 compression
one carb
875 horses at 6250 rpm
Fords
2112 is offline
