Engine Rebuild/ New to OSO >
Old 04-21-2008 | 07:31 PM
Wodster69's Avatar
Unhappy Engine Rebuild/ New to OSO
Hey there everybody. I've been reading the post and checking everything everybody seems to be pretty cool.
Well I finally got me a boat - a 98 353 fastech w/twin 502 mags. the other day I was out and the starboard motor failed. Oil and water all over the engine hatch. Got the motors pulled and the starboard motor striped down to the block. Looks like the the intake failed at rear where it blocks the rear water port on the head. The intake rotted away right there and dumped water in to the valley. Is this a common problem?? Any remedies to keep this from happening again? Rest of the engine looks good the motors where quicksilver repowers the tags say 04. the water jacket are pretty clean no scaling, didnt bend any rods. So i think i can get away with honing, rings and bearings. Does any have or know where i can get lower intake? Best place to get a rebuild kit? Any thing else i should do while there out?
This is my first personal boat and it was the first time out takeing the fiancee out (she was thrilled about the motor after we just spend the money to buy the boat) But i dont think anyone could have known it was going to happen. Bad luck i guess.
I appreciate any help.
David
Wodster69 is offline
Old 04-21-2008 | 07:36 PM
Elite Marine's Avatar
Was it a salt water boat?
The fear would be how is the other engine?
If you are rebuilding it yourself, we can get you the rebuild kit, otherwise you would be best served taking it to a local engine guy where you can get service and support. Make sure they stand behind the product and have a good reputation.
Sorry to hear about your situation. Welcome to offshore boating!!
Elite Marine is offline
Old 04-21-2008 | 07:41 PM
Wodster69's Avatar
Yes its a saltwater boat. I am, Well my mechanic is doing the work. Were going to tear down the other as well. That way I atleast know what i got.
How much is rebuild kit?
Thanks,
David
Old 04-21-2008 | 07:55 PM
hunster's Avatar
Have a merc dealer check the serial # on that block tag and see when they were put into service. Merc has a 2 year warranty on most of the quicksilver long blocks.
hunster is offline
Old 04-21-2008 | 08:43 PM
wrinkleface's Avatar
Welcome & good luck w/ your engine issues! Had a 353, my favorite Formula out of 4! Tracy
wrinkleface is offline
Old 04-21-2008 | 09:25 PM
Wodster69's Avatar
Thats good know. I'll check but if it is i doubt it would be covered. Because the intake failed and not anything with the rebuilt motor.
Thanks for the help,
David
Old 04-21-2008 | 10:07 PM
PhantomChaos's Avatar
Just to be clear........this has nothing to do with the failure..........only that if there is a problem......then you need to act faster.
PhantomChaos is offline
Old 04-22-2008 | 06:58 AM
You can have those repaired. They are very expensive to replace.
kennyo is offline
Old 04-22-2008 | 01:01 PM
Wodster69's Avatar
What is needed to convert to 525 efi setup?
Old 04-22-2008 | 01:48 PM
C_Spray's Avatar
Diamond Member #001
Complete engines, and probably drives...
C_Spray is offline
gotime34
07-10-2005 08:20 PM
QUIKDECISION
04-25-2005 10:47 AM
batty
10-04-2004 09:53 AM
Baja Bopp
6
05-21-2003 10:58 PM
florida gator
01-27-2003 08:02 PM
