Whipple 600sci upgrade documentation >
Old 12-01-2009 | 06:01 AM
  #51
Jassman's Avatar
Originally Posted by aTX427
the 600 / 700 is way detuned. How about the NXT trans? What are they rated at and are they breaking? I have only heard of two; one being driver error and the other was in a cat that is run hard in rough water - never heard the real deal on why it broke.
approx 800 hp/tq.. the Merc 700 which is rumered to put out 750-770hp is max on that drive... they were designed for this purpose only.. gap between #6 and the bravo.
Jassman is offline
Old 12-01-2009 | 09:28 AM
  #52
CB-BLR's Avatar
Chris
Getting a little off track here... but there is a twin-turbo Nordic Thor that is putting nearly 1400 hp thru an NXT, with no failures yet. I believe he has a BAM transmition waiting in the wings. The weak link on the NXT is supposedly the trannny.
Chris
CB-BLR is offline
Old 12-01-2009 | 11:13 AM
  #53
I WOULD LOVE TO TALKE TO THAT GUY
ARE YOU SURE YOUR NOT A SALESPERSON (for dustin) LOl
gnorthga is offline
Old 12-01-2009 | 11:25 AM
  #54
Were are you getting your data
gnorthga is offline
Old 12-01-2009 | 02:44 PM
  #55
CB-BLR's Avatar
Chris
He goes by "nordic 1" over in the Nordic forum:
http://www.offshoreonly.com/forums/n...2009-thor.html
I am not a salesperson for Dustin.... just an extremely happy customer!
Chris
CB-BLR is offline
Old 12-01-2009 | 05:13 PM
  #56
Beak Boater's Avatar
Charter Member # 545
approx 800 hp/tq.. the Merc 700 which is rumered to put out 750-770hp.
Not doubting you but what is Dustins stage II upgrade putting out then for the 700 sci? I thought it was around 800 hp. I'm sure he is making more than 50 hp with the ecu and pulley change.
Beak Boater is offline
Old 12-01-2009 | 10:51 PM
  #57
Whipple Charged's Avatar
Stage 2 is a conservative 830hp.
The only weakness in the NXT is really the tranny. We've used one on a 632ci 1300hp engine for 2.5 seasons in a single 30' Eliminator V. Blew tranny in first few hours which was do to the shifting at 800rpm (yes it idles at 800). I installed a shift interupt and its made it ever since. Brings rpm to 200 during shifts. We've got hundreds of NXT's running 800+ with zero issues.
Whipple Charged is offline
Old 12-01-2009 | 10:56 PM
  #58
Originally Posted by sport
Why is it that a 525 with a whipple can make 775hp with only 7 psi of boost and a 600sci needs 10-12 to make 750hp? I realize that the 525 has a little more comp. and a little bigger cam. I'm not trying to secound guess any one but that still sounds little a lot of boost. My new nordic 28 is being built with the 600sci and i know i will need more power when the warranty is up but i don't think i would fill good about running that much boost on pump gas. How much boost does the 700sci have to make 700hp? The cam is only slighty bigger in the 700 over the 600.
chris and eddie thanks for all the info
Cam is significantly bigger in the 700sci, they also have a 3/4" thicker IC and 2.5-3psi more boost. This comes out to 100hp more.
Mercury 1075sci runs between 12-13psi of boost with 91 octane and 8.0:1 compression. Also run 34deg of timing vs. 28deg of the 700sci. 700sci also works with 89 octane in stock trim so there's quite a bit left on the table.
Old 12-02-2009 | 05:56 AM
  #59
Jassman's Avatar
Brad from Mercury.. Trond and Terry from NorTech.. So Stay around the 800 mark or less... same as the stock 700 Merc's... on heavier and twin motored boats this is the max.. may be different on smaller and single applications like Dustin stated.. I'm going by a conversation as my boat was being built and I paniced when I saw the NXT transom assembly coupled to my 6 drive.. I was told leave it stock, and I wouldnt have a problem...No problems to date with appr. 120 hours
Jassman is offline
Old 12-02-2009 | 08:22 AM
  #60
Would you recommend a shift interupt to use on 700 NXT with one one of your upgrades?
we have 17x35 Harrings now what you think the rpms are going to come out to be
gnorthga is offline
