Thad Allen's Apache + The Birth of the Cheetah Cat >
Old 05-09-2010 | 05:35 PM
  #231
Steve 1's Avatar
Deck going on the stringers were glassed on in while in the fixture,Now just glass them Down to the hull,those bands on the bulkheads are added uni's
Front view
The holding fixture
Steve 1 is offline
Old 05-09-2010 | 05:37 PM
  #232
Steve 1's Avatar
Deck on and checking it out.That hull is cut off at exactly 10 meters.
Steve 1 is offline
Old 05-09-2010 | 05:39 PM
  #233
Steve 1's Avatar
Laying out for cutting the access panels which is the only way to work on this.
Steve 1 is offline
Old 05-09-2010 | 05:42 PM
  #234
Steve 1's Avatar
Access Panels cut and fairing starting soon race is getting near.Damaged photo.
Steve 1 is offline
Old 05-09-2010 | 05:45 PM
  #235
Steve 1's Avatar
Fairing started,Batteries go in through that access panel on the right.
Steve 1 is offline
Old 05-09-2010 | 05:47 PM
  #236
Steve 1's Avatar
Fairing the bottom.
Steve 1 is offline
Old 05-09-2010 | 05:49 PM
  #237
Steve 1's Avatar
Fairing the tunnel sides.
Steve 1 is offline
Old 05-09-2010 | 05:50 PM
  #238
Steve 1's Avatar
For the fairing compound I had my 3-M glass bubbles flown in as the filler and then mixed some of the laminating resin in to keep a common backbone so to say, then some white gelcoat, I could not find any wax solution in those days around there but I had styrene and paraffin so I made my own.
Steve 1 is offline
Old 05-09-2010 | 05:54 PM
  #239
Steve 1's Avatar
In 237 you can see how wide the tunnel is in this little Cat and here is a shot of the top sides getting close to longboard time and Epoxy primer, I have the Canards and linkage built, the Canopy has arrived.
Attached Thumbnails Thad Allen's Apache + The Birth of the Cheetah Cat-topside.jpg
Steve 1 is offline
  #240
Steve 1's Avatar
The Tunnel and keels are parallel looking up from below ,now the outside tunnel chine converges forward of the projected center of gravity giving that Illusion.
Steve 1 is offline
