Thad Allen's Apache + The Birth of the Cheetah Cat >
Old 05-09-2010 | 05:57 PM
  #241
Steve 1's Avatar
here was a good thing about that place the Acetone was costly and hard to get so I built a couple of these with parts from a hot water tank. This simple recovery system used the natural heat cycle to circulate cooling water through the condenser. In the background we were Building a Aluminum race trailer I worked out a Profile and had the Beams extruded.
Steve 1 is offline
Old 05-09-2010 | 05:59 PM
  #242
Steve 1's Avatar
Here is the recovered Acetone we got back 60-70% evaporation plays a large role here on the loss and the crew was taught to keep the containers covered and run two batches a day,It had a good flow.
Attached Thumbnails Thad Allen's Apache + The Birth of the Cheetah Cat-acetonerec2.jpg
Steve 1 is offline
Old 05-09-2010 | 06:02 PM
  #243
Steve 1's Avatar
Back to the Raceboat we carried everything up to the second floor including the Engines rigged and started it,Then had the roof opened and Hoisted it out with a Crane the national race was upon us by this time, we won btw Nice prizes .The photo is the canard I cut and shaped them on a table saw and covered with 8 pieces of 5.6 oz surf board cloth and 12 layers around the control shaft feathered out into the surface.
Steve 1 is offline
Old 05-09-2010 | 06:04 PM
  #244
Steve 1's Avatar
I flew the seats in from California, We built everything around the throttle man the driver got the wheel a compass and control stick for the canards to give him something to do.
Steve 1 is offline
Old 05-09-2010 | 06:06 PM
  #245
Steve 1's Avatar
Dash board and the white lever in front is the stick if the linkage ever failed the control surfaces would just assume a harmless neutral position in the airflow.The rear half of the fairing had the hatch on it as well with a single aircraft pull pin retaining it.
Steve 1 is offline
Old 05-09-2010 | 06:09 PM
  #246
Steve 1's Avatar
Here is the throttle seat I had the boat carpeted .
Steve 1 is offline
Old 05-09-2010 | 06:10 PM
  #247
Steve 1's Avatar
Seats were Mastercraft. I do not know who owns them now, back when we were using them a Chick owned it her father started the company and left it to her, she was a nice lady to deal with we had all their fabric samples , there was no other seat to even consider.
Steve 1 is offline
Old 05-09-2010 | 06:12 PM
  #248
Steve 1's Avatar
Here we are starting to play with the cowlings a two piece mold was made and the brick looking things were changed. that rear panel is over the battery and the fairing needs cleaned up and clear coated.
Steve 1 is offline
Old 05-09-2010 | 06:15 PM
  #249
Steve 1's Avatar
Drivers seat, the stick has 7 locked positions.
Attached Thumbnails Thad Allen's Apache + The Birth of the Cheetah Cat-throttle.jpg
Steve 1 is offline
Old 05-09-2010 | 06:16 PM
  #250
Steve 1's Avatar
We carpeted the interior for the boss I wanted to give him something different and had plenty of room in the weight dept.
Steve 1 is offline
