What to do on super chiller
Eddie
Cool thx. Also is there a better belt driven pump for more pressure and movement of water. This is a roots blower so I don't want any heat problems at all. Also this might be a dumb question but what about two oil coolers instead of one since the oil gets hot as heck in a boat especially a blown engine.
I like the tunnel idea and we can do that at my shop. I do that fiberglass for a living and paint boats, working on a 44 mti right now that got hit by a sign. I own fibertek marine on grand lake.
There is no need to go to a 2 stage pump unless you have a pickup larger than 1 1/4". It won't flow any more water. The Hardin pump is a nice piece. The water passages in and out of the pump are larger and smoother for better flow. I'm sure one of their pumps will flow more water than a Merc pump with a plastic housing.
Negative on the 2 coolers. One larger cooler will be more than enough. How much power? If it's less than 1000 hp, an oil cooler with a bundle length of 3" x 18"-20" should do fine. That's not the overall length, but the length of the bundle of tubes inside the cooler. You will need an oil thermostat or you will have problems making enough oil temp.
Eddie
Eddie
Ok I have all that . I believe it's a little bigger also. So good news I guess. I used to drag race with the I.h.r.a. And learned a lot from those guys but this boat stuff is a little confusing. I bought a callies magnum Xl. And want to protect it the best I can if you get my drift. Expensive but the crank is nice enough to hang on the wall.
Thank you for the info Eddie , very informative as always!
Btw , got any whipple intercooler cores laying around you wanna get rid of cheap ???
I`m starting a new intercooler charity...its for the CHILDERN.. mine wanna go fast!!
