AT vs. OL
#161
Maybe sommerfliesby can chime in on this. I went out for a ride on his 37 with 525s last spring. It was a brisk cool sunny day with great air temps. 3 guys on board. We went out and ran in some real snotty lake Michigan water. I was impressed with the boats ride and handling in the rough water. We got inside the breakwall area in protected waters, with probably around a 1-2ft chop. He put the throttles to the mat, I believe we were seeing 78-80 that day turning about 5200-5300rpm?. Which in my eyes, isn't anything to be ashamed of for such a large boat, with stock 525's. However, I would have a hard time believing he has 10mph in his setup with prop work and a light load. I can see saltwater and sea level in florida being worth a couple two three mph though. I know Mike logged some good time on his boat since he purchased it, maybe he can weigh in with some speed numbers on his particular vessel.
Dan...the fact that a 37 AT has run 90 with 525s has been hashed over again and again...but ALWAYS comes with the caveat of $6k worth of Herring props. I found a set of Herrings before I took delivery of the boat, and contacted Pat about what he thought about putting them on. He recommended against it due to the stress that would be placed on the drives, as getting out of the hole was VERY difficult with them on. I don't think Pat is "trolling" a thread when it is his boats that are being discussed, and nobody knows them quite like he does...
I love all these comparison threads...they seem to bring out the best and worst in comments. Also the informed and uninformed! And with Brownie's contribution...well...the master has spoken.
#163
#164
#166
#167
2001 32' Active Thunder, non step, twin 500's 3/4 fuel 6 people, 2011 Texas Outlaw Challenge registed GPS 82.7. That was my official turn in speed.
1999 37' Active Thunder, step, ordered and owned by Roy "Thunder Roy" Schneider, twin 500's with extension boxes, hit 90mph, all day, anyday.
Feel free to confirm the #'s Pat. You make an awesome product.
Comparing a Baja to Active Thunder, because of high sales #'s, is like comparing Meridian to Viking...
#168
Here is a picture of the attitude of the 36SL at cruise for those of you asking about running surface while under way. The boat runs very flat and it extremely stable at all speeds. We will have two 2014 Outerlimits 36SL's at the Miami show. The blue 520 boat will be in the water at Sea Isle. The 565 boat will be in the Outerlimits display outside at the convention center under tent. Come see the Outerlimits Powerboat and Performance Boat Center crews and determine for yourself which boat better fits your needs.
On a side note, if we were comparing a similar hull between Active Thunder 37 and Outerlimits, I would have to put the 37 AT up against the 37 Stiletto. Both are 37FT, bolt on swim platforms, single step, side by side seating, Tall top cap which results in a large cabin. The 37AT and 36SL are two completely different boats built for 2 completely different markets.
#169
#170
Now thats an efficient hull…
This was done with Herrings on it and Herrring has this recorded also
