Hard on the Drives???
Old 02-12-2014 | 10:27 AM
  #41
is this hard on the drive??? full throttle to straight full throttle reverse....
http://www.youtube.com/watch?v=68AOltMu768
You know, when I was much younger my brother and I did that in a Sea-Doo speedster. Granted no moving parts, but we did fill the boat with water up to the rub rail. I remember the sales guy telling dad "No way to sink this boat, not even your son's can sink it" Damn if we didn't try!
RT930turbo is offline
Old 02-12-2014 | 10:41 AM
  #42
onesickpantera's Avatar
Originally Posted by offshorexcursion
I know of many boats that blow bravos x and xr behind stock 496s or just plain wear them out within a couple 100 hours. They are a junk drive doesn't matter how much you baby them they WILL break prematurely
I agree that there have been some issues with certain XRs. But, people far more knowledgeable than me have highly recommended the X drive.
onesickpantera is offline
Old 02-12-2014 | 10:42 AM
  #43
Originally Posted by MILD THUNDER
While I see absolutely no good reason to do full throttle starts, what do you think they do during powerboat testing and performance reports? I'd probably rather buy a 33 Fountain with 496's that had some full throttle starts on a small lake or river, over the 33 with 496's that ran it offshore in big water like great lakes or the ocean getting it airborne every weekend.
Many times drives break not because of HP. Prop pitch, boat weight, prop style, x dimension, etc. Perfect example is the 42 Fountains with the dry sump 6 drives coupled to the 700SCI. The 700SCI isn't busting the drive. Its the high propshaft height, 6 blade props, high pitch, rough water etc. Then there are guys with dry sump 6's running a lot more hp through them on a 41 apache with no issues.
I can tell you from a friend who's developed a product, that you will see on the market very soon, the engine isn't breaking the drives in most cases. When you have torque sensors hooked to your driveshaft measuring the torque readings live and logged into a laptop, on flat ass calm water, the most the drivetrain will see is whatever the engine produces. Get into any kind of chop/rough water, even at moderate speeds, and you'll find the torque spikes on the drivetrain to be in the thousands of ft lbs.
Think of it this way. You can take a bone stock mustang and floor it from redlight to redlight without wheel spin, and the trans,rear axles will most likely take it all day long. Now, dump that clutch and let those tires break loose, spinning and smoking until they bite, and see how long before you smoke a rear end or snap an axle. Happens all the time in the big truck world. You can have a big old Kenworth with a 600 cummins in it, loaded to 80k+ lbs, and boost it up with your foot to the floor all day getting up to speed or climbing a mountain. Get that truck off the pavement in some loose gravel or mud, and get some wheel spin going while your foots on the throttle. That's when the service truck has to come out to replace a busted axle or pinion gear.
Take a slab of concrete and you can park a semi truck on it and not crack it. Smack it hard enough with a 20 lb sledge hammer and watch it crack. Concrete is strong, but brittle. Much like gears and shafts.
I'm sorry but your logic is flawed! Tires breaking loose and spinning takes the shock off a cars rear axles. Dumping the clutch with hot sticky slicks is when things break. Have you ever tried to break up a slab of concrete with a sledge? You cannot! It only chips. You must use a jack hammer.
thirdchildhood is offline
Old 02-12-2014 | 10:46 AM
  #44
Yes, I have. I worked on a concrete crew for years replacing city sidewalks. Every single day we would use a bobcat with forks, to lift up a 7ft x 7ft sidewalk slab on a 45 degree angle. In order to fit the slabs in the dump truck, or to separate them, a good smack with a sledge would snap them in half. Maybe you're logic is flawed.
Tires breaking loose takes the load off, however when they BITE again, is when $hit breaks.
https://www.youtube.com/watch?v=lKSs3I8v9tI
MILD THUNDER is offline
Old 02-12-2014 | 10:59 AM
  #45
In the drag racing world a clean launch rarely breaks anything. It's when you start to slip or wheel hop. If you break at launch your not setup right. Regardless that's cars we are talking outdrives couple of extra angles to figure in. And anybody who ever has done construction will tell you a sledge will break concrete just can't swing it like a purse.
MissBehavin777 is offline
Old 02-12-2014 | 11:12 AM
  #46
Actually MT hit the nail right on the head!
IMO, a wide-open holeshot is nothing compared to a "missed throttle pull".
Old 02-12-2014 | 11:18 AM
  #47
somersfly by sh!t usually breaks when the wife is at shore and we are out having way too much fun As far as the drive deal. Surface drive causes vibration that causes wear and stress.. Usually a surface drive ( bravo) will pop when secreaming to get on plane because of vibration. Or that will make it weak and then it will brak when under power. You have to look at all that boat weight . bow lift stress etc is all riding on those thin little propshafts. Reguardless of weather or not having extra bikini's cuases the stuff to break or not does not concern me. Just the amount of fun that takes place during the event is what mastterrs ! back to this guy. he looks like he is having fun.. just needs to hook up the red cord and keep his had on the throttle.
mcprodesign is offline
Old 02-12-2014 | 01:33 PM
  #48
bck's Avatar
bck
Charter Member#568
I know on my big blocks there was only a 48 lb-ft difference between 3000rpm and max torque and only 13 lb difference between 3000 and full throttle 5500. My motors aren't stock but pretty mild compared to a lot of the motors on here so not sure how it applies.
Straight bottoms and flat decks
bck is offline
Old 02-12-2014 | 01:55 PM
  #49
I've tried breaking up concrete with a sledge and only made chips. It wouldn't crack no matter how hard I hit it. Now if it were already lifted then it may be easier to break up. Tires do not spin and then magically hook up. You either hook up or go up in smoke. Anyway, carry on. I thought we were talking about boat drives..
Old 02-12-2014 | 09:00 PM
  #50
Dude, please don't comment on drag racing. I've been racing for years and find this comment offensively ignorant.
http://www.youtube.com/watch?v=HOmXCbVIU_c
abmotorman is offline
