Season over....tossed a rod... >
Old 08-26-2014 | 07:51 AM
  #181
Full Force's Avatar
Originally Posted by 4bus
Come on now........can't just jab it in there. We should have took the slow knife approach, and baited him into explaining his mess.
Be careful if he responds heated, cyber threats are taken more seriously than verbal today.
He won't even respond I already know that... Dave went rounds with this years ago... Like I said I thought the engines finally had been worked out after haing some time, should have waited longer to buy lol
Full Force is offline
Old 08-26-2014 | 08:30 AM
  #182
Full Force's Avatar
It gets better anybody see the issue here??[ATTACH=CONFIG]528382[/ATTACH]
Old 08-26-2014 | 09:03 AM
  #183
PatriYacht's Avatar
Is that a mark from the counter weight rubbing the bottom of the piston?
PatriYacht is offline
Old 08-26-2014 | 09:14 AM
  #184
Full Force's Avatar
Only thing I can think of! wtf I just noticed it this morning showing someone at work.
Old 08-26-2014 | 09:41 AM
  #185
Knot 4 Me's Avatar
Oh my...
Knot 4 Me is offline
Old 08-26-2014 | 09:43 AM
  #186
PatriYacht's Avatar
All I can say is.... Wow
Old 08-26-2014 | 10:24 AM
  #187
Pretty much has to be. The machining lines run the other direction until you get to that scuff, and those marks align with crank rotation.
Cole2534 is offline
Old 08-26-2014 | 10:35 AM
  #188
Full Force's Avatar
Exactly, looking at budget crank and rods I have some friends around here with connections for parts, I can get a deal on Manley it seems, h beams with arp2000 for just about 400-425 cost....looking into what cranks and a buddy can get racer discount at summit and they local to me..., looks like Ohio crankshaft has very good prices... Also local
Old 08-26-2014 | 02:45 PM
  #189
PatriYacht's Avatar
I got Compstar cranks for about 675.00. They were on the money on size and all journals were straight and within a couple of tenths of each other. A lot of low dollar cranks need work before you can use them. Eats up all of your savings.
Old 08-26-2014 | 03:24 PM
  #190
Originally Posted by Knot 4 Me
Oh my...
what size rods are in this motor?? 6.??? also some machinest will take off a little in that spot when ballancing the assy but it does look like it taped the crank's counter weight.. does it show a sign of it being internally balanced? small harmonic ballancer and no weight on the flywheel..
FIXX is offline
