Season over....tossed a rod... >
Old 08-26-2014 | 07:07 PM
  #201
Full Force's Avatar
Originally Posted by Cole2534
I'm not implying that you're dumb. Just trying to stimulate the mind for a little thought exercise, rather than the blanket 'I always do xxxxx' mindset.
Sorry, just being an engineer.
I learned 2 things over the years with engines, only trust yourself and smart buddy with own eyes, and doube check all machinework!
Full Force is offline
Old 08-26-2014 | 08:05 PM
  #202
Full Force's Avatar
Thinking the wear marks on pistons might be from crap getting wedged between, only 2 had them marks...seems to be internal balance..
[ATTACH=CONFIG]528430[/ATTACH][ATTACH=CONFIG]528431[/ATTACH][ATTACH=CONFIG]528432[/ATTACH][ATTACH=CONFIG]528433[/ATTACH][ATTACH=CONFIG]528434[/ATTACH]
Attached Thumbnails Season over....tossed a rod...-p1018932.jpg   Season over....tossed a rod...-p1018933.jpg   Season over....tossed a rod...-p1018935.jpg
Season over....tossed a rod...-p1018936.jpg   Season over....tossed a rod...-p1018937.jpg
Old 08-27-2014 | 01:56 AM
  #203
usually when they internally ballance the engine they add bob weight,,i like to use bryant and winberg light weight cranks and you will see a hole driller through the counter weight for internal ballancing..i dont ever remember seeing a 8'' ballancer with out a counter weight.. when you get it off look and see if theirs caster weight on one side and also look at the flywheel..over 600 hp i like to use a billit flywheen not cast..
FIXX is offline
Old 08-27-2014 | 02:18 AM
  #204
here is the crank out of my 632,,you can see the weight in the crank..you having a forged crank and 6.385 rods its soppose to be internally balanced..
FIXX is offline
Old 08-27-2014 | 04:33 AM
  #205
Full Force's Avatar
According to pbm it's internally balanced, I don't see any balancing holes in damper either.
Old 08-27-2014 | 06:41 AM
  #206
MER Performance's Avatar
BALANCING HOLES IN BALANCER???? The balancer is most likely; neutral ( no counter-weight )
MER Performance is offline
Old 08-27-2014 | 06:43 AM
  #207
Full Force's Avatar
On my fords the counterweight one side, holes or dimples on other. I will send pic later.
Old 08-27-2014 | 07:09 AM
  #208
Full Force's Avatar
[ATTACH=CONFIG]528439[/ATTACH][ATTACH=CONFIG]528440[/ATTACH]
Attached Thumbnails Season over....tossed a rod...-image.jpg   Season over....tossed a rod...-image.jpg
Old 08-27-2014 | 01:06 PM
  #209
PatriYacht's Avatar
On a Chevy if it's externally balanced it will have an added weight on the balancer and another one on the flywheel.
PatriYacht is offline
Old 08-27-2014 | 02:15 PM
  #210
SB
Not always. Some 1 piece rear seal motors the external balance on the flywheel is done by drilling out material - not by adding material.
This has caused many fits getting flywheels for motors - especially the small blocks when stroking. Once the info is known, the fit stops. LOL. Thus why I'm sharing this.
SB is offline
