Salt water help
Old 10-29-2015 | 01:44 PM
  #141
Originally Posted by JRider
You have more time than me! There is a boat that I am looking at in New Orleans right now that the owner said has been ran in brackish water. Which is true judging by the poker runs he has been on but those poker runs go through salt as well so he failed to leave that part out. From the limited number of saltwater boats I have been in they are not on par with freshwater boats of the same age. I am not saying they do not exist. I am afraid of flying down to New Orleans for a big $150k disappointment.
Is he willing to maybe grab a paper with a current date and take a few crucial area pics? I can completely understand someone from up north having some worries, myself personally I would do all I could to settle their mind and show them my boat is as advertised make sure they are not wasting their money and time on a trip.
Also yes...I have wayyyy too much free time. It's wax the truck or hit the bar.....sometimes both lol
Nate5.0 is offline
Old 10-29-2015 | 02:57 PM
  #142
Do yourself a favor, don't buy a salt boat. The differences are not all visible.
AJ POWERPLAY is offline
Old 10-29-2015 | 03:16 PM
  #143
Dean Ferry's Avatar
Veteran: Air Force
[QUOTE=ajfisher;4371052]Do yourself a favor, don't buy a salt boat. The differences are not all visible.[/QUOTE
Well, the same can be said for a freshwater boat from Michigan, that wasn't "Winterized" properly, and there could be cracks in the blocks from them getting frozen, and that is not visible, until you run the boat, and I don't mean running on the hose either.
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 10-29-2015 | 08:54 PM
  #144
rak rua's Avatar
I'm depressed. Based on overall weight, I have approximately the same percentage of salt in my body as there is salt in the oceans. I am now afraid that because of the salt in my body, if I make contact with my boat it will cause the boat to corrode.
Maybe I should get a sacrificial anode fitted to my body so as to isolate the inherent corrosion problems to one area rather than spread them to my boat. Maybe I'll sell the boat or donate it to a local salt recycling plant and have it with my French fries.
RR
rak rua is offline
Old 10-29-2015 | 08:56 PM
  #145
Our bodies are salt batteries. Without salt we can't send electrical pulses and we die. Not to mention French fries taste like ass without salt
Drew555 is offline
Old 10-30-2015 | 07:02 AM
  #146
[QUOTE=Dean Ferry;4371056]
A block is typically obvious to find, even on a hose. Just look in the bilge and you will see water spraying. The internal parts that concern me on a salt water boat are innercoolers and aluminum heads. How can the condition possibly be known?
JRider is offline
Old 10-30-2015 | 07:51 AM
  #147
double post
Speedracer29 is offline
Old 10-30-2015 | 07:53 AM
  #148
Could you pull the thermostat or intercooler line and use an inspection camera to look inside?
My limited knowledge of aluminum oxide tells me it clings to itself pretty good and forms a strong barrier quickly, but on an iron block with aluminum heads I'd be worried about galvanic corrosion, and that's waaaay out of my wheelhouse.
Old 10-30-2015 | 08:02 AM
  #149
badmonkey's Avatar
RR
Freakin hysterical...Thanks, I needed a really good laugh...
Chris
badmonkey is offline
Old 10-30-2015 | 09:10 AM
  #150
Dean Ferry's Avatar
Veteran: Air Force
[QUOTE=JRider;4371223]
Not all, I've seen a block freeze on a friend's boat in N. Dakota, that didn't show up on the Spring De-winterize run on the hose activity. But 2 weeks later after he launched, running/idleing for 5-10 minutes, he got oil pressure problem and a chocolate milkshake in the oil pan......
