Start to Finish: Building Our 50' Skater >
Old 08-26-2019 | 11:51 AM
  #1811
Goo to hear you are still at it and good to hear you are able to find the time to work on your own project as it seemed like for alot of the build you were getting your biggest steps going forward when the snow was/was about to fly.
Awesome Build!
speicher lane is offline
Old 08-26-2019 | 04:52 PM
  #1812
Quinlan's Avatar
Remember I'm There for ya anytime for testing. This was Jan this yr.
Beeech Blows some Smoke when exhaust welds let go.
Tristin was like - "Tyson I don't think that is RIGHT" lol
Quinlan is offline
Old 08-26-2019 | 05:53 PM
  #1813
BigSilverCat's Avatar
This is the video from when Quinlan from the post above met me at the lake to help us take it out. Welded a few things and went to test some different props. It broke a different weld before we even got on plane.
BigSilverCat is offline
Old 08-26-2019 | 05:58 PM
  #1814
Bummer
AllDodge is offline
Old 08-26-2019 | 08:29 PM
  #1815
PigNaPoke's Avatar
Unreal you had that many welds on a brand new rig that were faulty.... keep at it eventually the whole bilge will just be filler rod 😂🤣
PigNaPoke is offline
Old 08-26-2019 | 09:26 PM
  #1816
This is the exhaust pipe between the two compound turbos In the above video. It split apart so far I thought there was a pie shaped piece missing till I got it out of the boat. There is a stainless steel flexible bellows on that tube so it was not a stiff connection.
Old 08-27-2019 | 06:52 AM
  #1817
Was all that bad welding in the Fab from the engine builders?
Old 08-27-2019 | 12:15 PM
  #1818
Wobble's Avatar
SORE MEMBER
Damn, that is some depressing stuff. I do admire your perseverance.
Wobble is offline
Old 08-27-2019 | 01:02 PM
  #1819
Keytime's Avatar
Originally Posted by BigSilverCat
If I can get the welds to hold I will start trying to do some short distance runs of a few hundred miles to see if the engines will hold up.
Hmmmm... dam to dam to dam?
Keytime is offline
Old 08-27-2019 | 02:55 PM
  #1820
Almost endless miles to run up here in CA Delta & SF Bay. Hope to see you sometime.
lake p.a.l. is offline
