Winter rebuild Saris racing >
Old 12-17-2024 | 02:20 PM
Talked with Jason, yesterday. The old engine has been torn down and inspected. All looks good for the rebuild. Cylinders had some water damage due to inversion and was likely making the blowby worse. Will need at least tails and maybe new exhaust manifold. Sent a check to get things rolling. Going to rebore to 540 new aluminum heads new induction and ignition system. Now, I can't wait for spring to get here.
Padraig
Padraig is offline
Old 12-17-2024 | 02:27 PM
F-2 Speedy's Avatar
You'll like the 540 built a couple yrs back with Smith Power, whats the head and cam choice ?
F-2 Speedy is offline
Old 12-17-2024 | 03:34 PM
TeamSaris's Avatar
Driver-441
Racer
4.25 compstar crank/rods, 9.5 comp JE pistons, afr heads, holley intake/efi, isky cam
TeamSaris is offline
Old 12-17-2024 | 04:57 PM
Thanks, Johnny!
Padraig
Padraig is offline
Old 12-17-2024 | 07:46 PM
SB
braap ! braap!
ooops, i mean vroom vroom !!!
Padraig, you where at 502cid’s before right ?
SB is offline
Old 12-17-2024 | 08:40 PM
Originally Posted by SB
braap ! braap!
Yes
Padraig
Padraig is offline
Old 12-17-2024 | 09:25 PM
F-2 Speedy's Avatar
I ran the same cr with a 305 as cast AFR.........4.500 x 6.385 made good power through a 500 EFI plenum...625.you should be above that with better intake and fuel distribution
Old 12-18-2024 | 04:23 AM
Thanks. When it is ready for the dyno, They have invited me up to watch.
Padraig
Padraig is offline
Old 12-18-2024 | 05:49 AM
Keeping tabs on this build! That should be a beast!
Gary C is offline
Old 12-19-2024 | 02:05 PM
Heard from Jason. My old CMI headers will not accept tail pipes and CMI cannot modify for tail pipes. He is suggesting a CMI E top system or a IMCO Power Flow with long riser pipe. Both will solve the reversion issue he is seeing. The CMIs are definitely prettier. I also worry about if the IMCOs will make it more difficult when changing spark plugs, I am not too limber, at my age.
Any thoughts or pros and cons are welcome.
Padraig
Padraig is offline
