Like Tree0Likes
Flushing W/ Thru Hull Pick Ups
Old 03-30-2005, 10:57 PM
Default Flushing W/ Thru Hull Pick Ups
There Has To Be A Better Way To Flush Motors With Thru Hull Pick Ups. Stuffing A Garden Hose Up The Water Pick Up And Taping It Off Is Just Not Working. Please Help!
tomcat3 is offline
Old 03-30-2005, 11:05 PM
Tonto's Avatar
Default Re: Flushing W/ Thru Hull Pick Ups
tomcat3,
You put a "T" in the water inlet hose after the strainer and before the raw water pump and run a hose to a ball valve with a hose inlet on it. This way you can flush the strainer before you start the engine. After that just turn off the valve that lets raw water in and open the fresh water valve and fire it up.
Robert
Tonto is offline
Old 03-30-2005, 11:08 PM
GLH
GLH's Avatar
My Boats: Azimut
Check this thread it has some info for a good setup...
http://www.offshoreonly.com/forums/s...ad.php?t=97653
GLH is offline
Old 03-31-2005, 11:28 AM
Beak botr
88Fount33's Avatar
My Boats: 1988 Fountain 8.8
I had off the shelf "Pro Flush" from West Marine installed two (2) years ago. It is self contained and is located between the strainer and the seawater pump. It has an internal check valve to shut off the transom pick-up when the garden hose is attached and running on the under hatch flush fitting (not included). This has worked flawlessly once moved from the raw water side of the strainer. Moved it one year ago as it was trapping grass and debris in the check valve and spring asm.
Wasn't cheap, had to have two of them, but there are no valves to deal with and works perfectly.
88Fount33 is offline
Old 03-31-2005, 12:50 PM
JUSTONCE's Avatar
My Boats: boatless
Quote:
Originally Posted by Tonto
tomcat3,
Robert
This is how mine is set up and works great. One valve on the p/u side and one on the alternate input. Just don't forget to open the p/u side when you splash the boat before lighting her up.
JUSTONCE is offline
cougarman
12-05-2006 03:21 PM
sejman
3
04-05-2005 05:53 PM
mcraymond3
2
03-30-2005 09:24 PM
Maximus
04-30-2004 07:29 PM
enticer
2
09-15-2002 07:13 PM
