Procharger experts needed >
Old 06-27-2005, 02:47 PM
  #41
tssteph's Avatar
Default Re: Procharger experts needed
Yep thats it.... You want me to call you?
Brian
tssteph is offline
Old 06-27-2005, 02:51 PM
  #42
articfriends's Avatar
[QUOTE=tssteph]Yep thats it.... You want me to call you?
Brian[/Q
its on its way
articfriends is offline
Old 06-28-2005, 06:23 AM
  #43
tssteph's Avatar
Smitty, I will call you first thing this morning.
Thanks again.
Brian
tssteph is offline
Old 06-28-2005, 08:40 AM
  #44
I'm running 42psi at idle & 60psi at full throttle @ 5 pounds of boost. Just upgraded my pumps from essex to aeromotive . At 5400rpm the motors make 660 hp and 700foot pounds of torque.
baja27 is offline
Old 06-28-2005, 08:45 AM
  #45
tssteph's Avatar
Smity,
Just left you a message.
Brian Stephens
2614 SR 232
New Richmond Ohio 45157
tssteph is offline
Old 06-28-2005, 01:04 PM
  #46
Originally Posted by Pantera28-650HP
Smitty -
What are your feelings about 43# Injectors for 640HP. Also they are the disc style injector. I'm working with Bob on a new cam, but may want to change injectors to 50# and reflash the ECM on the dyno with the new cam and injectors. Any recommendations?
I was making over 700 hp last time around in the boat w/stock 43 lb injectors at 70 psi fuel presure but if you have chanch put bigger injectors in and have fuel curve done on a dyno. They also make a 63 lb high impedance injector but i had to go thru great measures to use them. Crockett might have a good flash for your computer for what your doing without putting your motor on the dyno.Smitty
Old 06-28-2005, 05:50 PM
  #47
Originally Posted by tssteph
Smity,
Brian Stephens
2614 SR 232
Brian,it went out UPS today,hope it fixes your problem,glad i could help you,Smitty
Old 06-30-2005, 09:16 AM
  #48
tssteph's Avatar
Smitty,
Got the pump, thanks a lot. I have not installed yet. How much was shipping? Let me know and I will throw some fun tickets your way.
Thanks again...
Brian
tssteph is offline
Old 06-30-2005, 06:07 PM
  #49
S/H was just under 10$,there is a area surcharge to you i guess.Smitty
Old 07-09-2005, 11:48 PM
  #50
This thread got off its original course but that is what it is all about. I just wanted to follow up with my fix. I got the suggestion to junk the ATI red regulator too late. I had ordered a new needle and seat as the original one USED had a wear mark. At first, although improved, the regulator fluctuated enough @ idle to not fix the original low speed portion of the problem. The new high speed adjustmeant yielded a much improved 50# regulation. Just came back from 9 days of running on Shasta Lake, and the old red rat has settled down considerably, both high and low speed are now +/- 2PSI.
baronbob is offline
Quick Reply: Procharger experts needed
