Problems W/ Alpha One >
Old 06-22-2005 | 10:08 AM
Question Problems W/ Alpha One
Just Purchased 1988 Wellcraft Nova Spyder / 350 Mags. Port Prop Is Rubbing On Gear Case, Does Any One Know What Would Cause This.
Note: Spacer Between Prop And Gear Case Is Installed. Is There Just One Spacer Or Two.
Also The Engines Are Fresh Off Rebuild With Some Engine Mods, Nothing To Crazy. I'm Guessing Maybe 300hp Each.
grand lake is offline
Old 06-22-2005 | 10:21 AM
Wally's Avatar
Were doomed!
Default Re: Problems W/ Alpha One
Try swaping the spacers from the other drive to se if it clears then.....the spacers are made of a soft material...brass....and could wear down and need replacement.....if that dont work i would look at your prop to make sure its correct for your application
-Wally
Wally is offline
Old 06-22-2005 | 10:50 AM
Good Idea
Old 06-22-2005 | 12:52 PM
spacers? I assume you are talking about thrust washer?
Try swamping props and see if it is the prop.
1BIGJIM is offline
Old 06-22-2005 | 01:15 PM
Wally's Avatar
Were doomed!
Yes he is referring to the thrust washers.....being that he called them spacers i had a brain fart and couldnt think of the term for them!
gl, if you take a look at the thrust washer when you remove it theres a beveled edge on the inside of one edge.....that mates with the Chamfer of the prop shaft when puting it back together.....just so you know
-Wally
Wally is offline
Old 06-22-2005 | 02:44 PM
Iggy's Avatar
Does the prop have a machined step at the gear case side?
It should look like this........
Attached Thumbnails Problems W/ Alpha One-correct.jpg
Iggy is offline
Old 06-22-2005 | 02:45 PM
Iggy's Avatar
Not like this........see, no step....
Attached Thumbnails Problems W/ Alpha One-incorrect.jpg
Iggy is offline
Old 06-23-2005 | 08:07 AM
Fixed It. Trust Washer Was No Good.
Thanks For The Feedback.
Old 06-23-2005 | 08:13 AM
Wally's Avatar
Were doomed!
Ah....i wish all boat fix's were that easy!
-Wally
Wally is offline
Superboat502
Drives and Lower Units
29
06-30-2007 07:30 PM
srracer
2
04-20-2006 03:49 PM
grand lake
3
09-26-2005 11:52 AM
