Greasing the Coupler >
Old 06-26-2005 | 08:23 PM
wtpowered's Avatar
Default Greasing the Coupler
I feel like a fool for asking but I can't stand on my head any longer....... Is there a grease fitting for the engine coupler, or do I need to pull the drive and grease the splines by hand.
wtpowered is offline
Old 06-26-2005 | 08:33 PM
Roger 1's Avatar
Default Re: Greasing the Coupler
On my bravo there is a grease fitting that you can get to without pulling the drive. You must pull the drive however to grease the u joints. Mercruiser specifies that the u joints be lubed every 50 hours of operation.
Roger 1 is offline
Old 06-26-2005 | 08:34 PM
wtpowered's Avatar
Ok.... Where is it??
Old 06-26-2005 | 09:55 PM
Dock Holiday's Avatar
Charter Member #34
The coupler is round like a drive shaft off the back of the engine going into the transom assembly.
Get on top center of the back of the motor and look straight down.
There is a grease fitting on it.
I pull the kill switch so the motor will not start and have the wife crank the engine over until the grease fitting appears on the top of the coupler.
It is not too hard.
Dock Holiday is offline
Old 06-27-2005 | 07:02 AM
East Coast B's Avatar
Bravo grease fittings.....
1 zerk - outside of gimble for the gimble bearing
2 zerks - pull drive, zerks are located on universal joints
2 zerks - located 180 degrees from one another on coupler, this is on a 454mag
2 zerks - located on mercruiser factory steering
Pretty much all are a pain in the ass except the gimble zerk... for the coupler, use the mercruiser spline grease, it's under 10 bucks... replacing a coupler is not cheap, motor has to come out, just went through this on my starboard motor.... Good Luck!!
East Coast B is offline
Old 06-27-2005 | 07:59 PM
wtpowered's Avatar
Thanks guys...... I just needed to bump the motor over a little.
Coupler is greased!! Boat is in the water. All is good!!!
nova26
Do It Yourself, Boating on a Budget
8
06-04-2008 03:37 PM
StrikinLightnin
Drives and Lower Units
2
08-13-2007 11:01 AM
docmanrich37
17
06-29-2007 07:53 PM
hp500efi
21
07-01-2004 09:33 AM
Julio
3
02-19-2004 07:04 AM
