Bravo 1 engine coupler >
Old 07-19-2005 | 05:28 PM
QUIKDECISION's Avatar
Default Bravo 1 engine coupler
I was just cleaning up the bell housing and engine coupler, getting ready to install the engines after a rebuild... I noticed that one coupler's splines are sharp teeth rather than the nice square edges... I am going to be looking for one.. Can't afford new... The engine rebuilds are draining me...
I have the Famous... Bravo 1 drives.. around the 1988 Vintage.
Would a coupler from a bravo 2 fit a Bravo 1 drive?
Thanks much....
Quikdecision.
QUIKDECISION is offline
Old 07-19-2005 | 05:37 PM
Dave M's Avatar
Veteran: Navy
Default Re: Bravo 1 engine coupler
Well, if in doubt I would find the $$ to get a new one. If you bolt everything up and you blow the coupler it's going to cost a lot more. Don't know about the Bravo 2 coupler. You can compare the part numbers here......
http://www.mercruiserparts.com/
Dave M is offline
Old 07-19-2005 | 05:47 PM
formula31's Avatar
Ive got 2 good ones that will work if youre not using the through prop bullhorns. They are the early style made from aluminum plate. In very good shape. rogue2800 at Hotmail.com
formula31 is offline
Old 07-19-2005 | 06:40 PM
GOODT's Avatar
Yes They Will Work Only Diiff Between Bravo One And Two Are In The Lowers
GOODT is offline
Old 07-19-2005 | 07:13 PM
Thanks you guys, for the help....
Much appreciated... This site is Awesome...
Old 07-20-2005 | 10:23 PM
50boat's Avatar
try ebay
50boat is offline
Old 07-21-2005 | 09:06 AM
I have a used one from a HP500 with 90 hours for $100
Shawn
shawn is offline
Boomer35
10-21-2008 11:46 AM
tbanzer
4
06-19-2007 12:47 AM
mopower
10
06-25-2005 10:09 PM
jafo
14
10-17-2002 05:58 PM
BAD-HABIT
6
03-19-2002 08:42 AM
