CMI Tailpipe Preferance >
Old 02-17-2006 | 09:04 AM
rws's Avatar
rws
Default CMI Tailpipe Preferance
I have to decide which way to go, thru transom "wet " tailpipes with trim rings and gaskets or tailpipes that terminate in the boat and install Transom tips.The boat is my Python project and the transom has not been drilled yet.I was concerned about taking on water, if i go with the thru transom pipes .
The Transom tip style are known to have more reversion issues.Engine is a 540 Na. Cam is a Crane 741.Please tell me your experiences.
Rob
rws is offline
Old 02-21-2006 | 02:38 PM
Default Re: CMI Tailpipe Preferance
If you have much of a cam at all absolutely go through transom with the pipe. I've had through transom for years. No problem with water getting in. I just sealed the pipes around the cut-out. I recommend using anything other than 4200 or 5200. Those two are fantastic sealants, but not great when/if you ever need to remove the pipe. 5200 can take away fiberglass trying to get it loose. Use a sealant that's a little less permanent. You'll never have to buy exhaust hose and clamps again either.
deboatmon is offline
Old 02-21-2006 | 03:48 PM
Panther's Avatar
Frank's Marine Service
I'd go with thru-hull all the way, no tips.
Get the beauty rings from Teague (page 82); http://teaguecustommarine.com/2002/c...interface.html
Panther is offline
Ran-Dom 32
10
10-15-2007 02:53 PM
25 hors la loi
10-15-2007 08:46 AM
layton
6
07-08-2005 06:02 PM
revomaniac
2
04-25-2005 01:00 PM
220EagleXp
04-05-2002 06:39 PM
