Solid Motor mounts >
Solid Motor mounts
Solid Motor mounts
Old 03-30-2006 | 02:24 PM
Dave M's Avatar
Veteran: Navy
Default Re: Solid Motor mounts
Originally Posted by Phazar454Mag
I have bought a Formula 292 Fastech without engines installed, but I got 2 new blue Scorpion engines in crates that I am going to install. The mounts are from Gil and I guess you would call them "solid mounts", but how do I align the new engines using these Gil mounts ? Can I simply loosen the bolts, adjust and tigthen ? Or are shims required for alignment ?
Thanks.
The mounts came with the boat? If so, and it had SBC's before, the mounts should already be lined up.
Dave M is offline
Old 03-30-2006 | 02:36 PM
Yes, the mounts came with the boat. The factory installed SBC's (used to be 350 Magnum MPI's) from Formula were in the boat the first time I saw it. When I decided to buy it the engines had been removed to prepare the upgrade to Scorpion engines. So I assume that the mounts are factory aligned to SBC's. Just wondering whether there could be small differences between engines such that alignment is required ?
Phazar454Mag is offline
Nordicflame
Wanted
9
11-13-2008 12:59 AM
littledcsrodshop
Wanted
3
03-15-2008 03:19 AM
superwrench0166
Detailing, Painting, & Fiberglass
0
07-24-2005 05:22 PM
CN24
3
01-15-2005 07:14 PM
convincor
Checkmate
50
07-11-2003 08:53 PM
