Dumb Carb question! >
Dumb Carb question!
Dumb Carb question!
Old 05-04-2006 | 09:45 AM
Default Dumb Carb question!
With the engine running I was checking to watching to see at what RPM the throttle plates start to open on my 750 DP Deamon. When the plates are open shouldn't gas being coming out of the top rear barrels like the front?
I was watching it with the plates about half open 3,500 RPM
and I can see no gas being dispensed
1BIGJIM is offline
Old 05-04-2006 | 10:06 AM
Default Re: Dumb Carb question!
Guessing the boat was in neutral.
In spite of the mechanical secondaries starting to open, there probably wasn'yt enough air flow to pull fuel from the secondary bowls.
rdoactive is offline
Old 05-04-2006 | 12:25 PM
Yes and on a trailer
The plates where about half way open. I still would have expected to see gas mixing with the air.
1BIGJIM is offline
Old 05-04-2006 | 05:39 PM
Strip Poker 388's Avatar
Rob
In my Scarab I rode in the engine compartment looking down the barrels just to see how much fuel was dropping and if there was any difference between them. It will be different on the water in gear because of load.Theres a lot of fuel at 3000-3500 coming out of the boosters when ya running across the lake.you can also listen to the engine .With the stelling exhaust it didn't get that hot to burn ya. Its pretty loud in there especially when you testing for knock/pinging under full load.I haven't tried it on the Hustler no room in there
Rob
Strip Poker 388 is offline
Old 05-05-2006 | 06:47 AM
Ya, that's an idea..
I could use the sun deck as a hydro-foil wing
1BIGJIM is offline
Old 05-05-2006 | 08:46 AM
Take pictures if you get that boat "sailing".
BTW, Carter/edelbrock carbs have an additional circuit to provide fuel at partial secondary opening. It's below the throttle blades, so you dont see it. Not sure if Holley/Deamon do something similar.
smdude
1
10-23-2007 08:14 PM
Freeryd
05-23-2007 03:15 PM
Jayl13
Apache
19
06-04-2006 07:58 AM
formula1
12-04-2003 08:56 AM
ThirdBird
02-19-2003 06:06 AM
