Coupler Strength >
Coupler Strength
Coupler Strength
Old 06-01-2006 | 11:07 PM
Default Re: Coupler Strength
Thanks a ton!!!!
ghittner is offline
Old 06-01-2006 | 11:21 PM
axapowell's Avatar
Where To
You bettcha!
Dave
axapowell is offline
Old 06-01-2006 | 11:55 PM
Panic Button, I sent you an Email re 1989 drive. Is it true that an A11 coupler will not fit an 89 Bravo?
ghittner is offline
Old 06-02-2006 | 06:49 PM
Panic Button's Avatar
Emerald Coast of Florida
I had to change the flywheel housing (865657A04) to use the HD coupler. The original was way to small. I found it used online for about $100. I don't remember the company except they were in NJ. Make sure it has the cut out on the bottom, the PN above does.
Ebay
Panic Button is offline
Old 06-03-2006 | 06:19 PM
[QUOTE=TC]Alignment is a real killer for couplers! We have thrown some pretty high HP numbers on stock couplers with good long term results. I have also seen a 25 Outlaw with 100hrs sheer the splines surely due to bad alignment. I would definitely spring for the coupler Smitty mentioned with extended splines next time.
TC - Do you work for Kellogg's? I see Tony the Tiger in your avatar.
Escape Velocity is offline
Old 06-03-2006 | 08:21 PM
offthefront's Avatar
this the extended one ? Bam list it at 508.00 retail ...432.00 Bam's price ....
offthefront is offline
Old 06-03-2006 | 08:24 PM
That's the coupler and flywheel housing I used.
tamburello
Cigarette
32
11-23-2024 10:05 PM
thisistank
Cigarette
1
04-30-2007 04:04 PM
HPJunkie
6
04-07-2007 04:45 AM
dennyp123
04-24-2006 04:12 PM
375stinger
Cigarette
5
10-03-2004 08:33 AM
