94 502 running problem??????    help!!!  pos vapor lock??? >
Old 06-26-2006 | 09:52 PM
Default 94 502 running problem?????? help!!! pos vapor lock???
I just bought this boat with a blown motor. rebuilt it and ran it for about 10hr. runs great BUT!!!! it seem to have one problem, after you run it for a 1hr or so and stop, shut it off and let it set on a heat soak, sometimes it will not start back up. it acts like it is flooded out ! you have to hold the throttle wfo to get it to start . when it does start it dont black smoke, like it was flooded out or anything. but it will not idle at all ! now this dont happen all the time . just about 90% of the time and only when it is warm. it runs great when cold it runs great the rest of the time .
1994 502 efi
brent72132 is offline
Old 06-26-2006 | 10:44 PM
Default Re: 94 502 running problem?????? help!!! pos vapor lock???
I had the same problem with my 93 502 MPI the diaphragm in the VST had a small hole in it and it would dump allot of fuel down the vent tube into intake runner #8. this caused a very hard start. Im not sure if the EFI has the same fuel delivery system thou.
LAXBAJA is offline
Old 06-29-2006 | 07:12 PM
not sure if they are the same when it happens it dont act like it is flooded just one cyl. out it act like all 8 are
rssteiny
22
08-25-2008 02:16 PM
kennyd
Baja
4
07-29-2008 08:07 AM
rssteiny
Active Thunder
0
04-06-2008 03:53 PM
cloudmaster_321
1
09-07-2006 07:20 PM
bj502
12
03-15-2004 08:12 PM
