fuel sending unit problem >
Old 07-07-2006 | 02:56 PM
Default fuel sending unit problem
Put the boat away last fall, fuel guage worked fine. Getting ready for launch I drained the tank and filled with fresh fuel. The new ethanol stuff. Used about a half tank but the guage still reads full. I pulled the sending unit and when its out the guage reads empty, which is what I would expect. I filled a bottle with gas ( old stuff) put the sender in and it reads full. As I take the unit out the guage goes down accordingly but when I put it in the half full tank it reads full. The sender is the type with just a tube, no float. Could this have anything to do with the ethanol? Anyone else experience this?
CN24 is offline
Old 07-07-2006 | 03:22 PM
GOODT's Avatar
Default Re: fuel sending unit problem
there should be a screw on top for calibration I would put back in and try fine tuning it and see if it makes any differance if not replace......
GOODT is offline
Old 07-07-2006 | 04:14 PM
There's 2 screws. One for empty and one for full. Adjusted both. It works fine out of the tank in an external container but when I install it using the same electrical connections, it reads full. WTF.
CN24 is offline
Old 07-07-2006 | 04:32 PM
GOODT's Avatar
it might be the ethenal in the fuel because it has a different specific gravity
not really sure but here is a link you can try to check out
http://www.livorsi.com/tools.htm
GOODT is offline
turnerrd
Velocity
5
06-29-2006 09:19 PM
adamrush
05-19-2005 07:43 AM
evelkevin
6
07-06-2004 07:57 PM
halffast_2003
1
07-21-2003 04:20 PM
GregP
5
04-19-2002 08:13 AM
