MSD 8366 vs 8560? >
MSD 8366 vs 8560?
MSD 8366 vs 8560?
Old 07-24-2006 | 10:51 PM
INDY27's Avatar
Default MSD 8366 vs 8560?
Anyone here used the new 8366 in a 502 MPI? What about the 8560? http://www.msdignition.com/mari_6.htm Any pros or cons? The 8366 looks like its the way to go, plug and play on the EFI motor.
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 07-24-2006 | 11:02 PM
Ted G's Avatar
Default Re: MSD 8366 vs 8560?
I'm really not sure what they could do for the EFI motor, advance is set by the ecu, so nothing is tunable. Might just want to buy a good cap and rotor and your done. I just got a new distributor off of e-bay for 69 bucks plus shipping, had a new coil, module, cap, and rotor. Works like a dream and even has the little screens in the vent holes.
www.cbpba.com
Ted G is offline
Old 07-25-2006 | 07:37 AM
The ignition module on the ready-to-run distributor is below the breaker plate and is not field serviceable.
Olds Eddie is offline
Old 07-25-2006 | 08:12 PM
INDY27's Avatar
The 8366 has a oem style ignition module, have you looked at it?
INDY27 is offline
Old 07-26-2006 | 01:23 AM
articfriends's Avatar
I saw no difference going from a oem dist to the 8366 on my mpi motor and I'm running signifigantly more power and fuel thru it than stock. My original one was 4 years old and looking kinda green,the msd lasted 2 seasons before it rotted apart internally and I'm running fresh water! I stuck the original one back in last season and its still working,just got the msd back from having it rebuilt,I'm going to run it because original might give up the ghost soon but if your looking for a performance gain and your original one is still working good/looking good don't waste your money,Smitty
articfriends is offline
Old 07-26-2006 | 07:17 PM
INDY27's Avatar
Smitty,
My stock one just died at 10 yrs old and I found a good deal on a brand new 8366 for only $227 delivered. I have a 1996 27' Fountain with a 502 MPI, M3sc ProCharger,headwork, roller cam, CMI's etc. Do you run the MSD igniton box?
INDY27 is offline
Old 07-26-2006 | 08:26 PM
I'm running a msd 6btm and adapter harness. I was running msd's hei coil too,it burned up last season(loose coil wire allowed it to arc and short out) and I put a stock auto parts store one on to get it running again and runs the same,Smitty
On a mpi motor if your msd box quits you can just unplug everything and plug it in stock and you won't be stranded,just a tidbit of obvious info people overlook.
pkspx
61
08-20-2015 09:06 AM
Ran-Dom 32
Wanted
0
02-21-2008 02:51 PM
ekcivic1
3
08-16-2006 10:32 PM
fulloblarney
16
06-09-2004 12:26 AM
CAP071
28
03-17-2003 07:08 PM
