525SC fuel pump. >
525SC fuel pump.
525SC fuel pump.
Old 08-19-2006 | 09:55 AM
dykstra's Avatar
Red face 525SC fuel pump.
Ok, so I am running along with plenty of fuel and I notice, no fuel pressure. I lift the hatch and there is fuel in the clear vent tube from the fuel pump to the flame arrestor. So am I correct to assume that it is a bad fuel pump? If so, do I have to prime the whole system again? There isn't any fuel in the bowls and the whole system was "sucked" dry. What is the best way to prime the system with the new pump. By the way, the new pump is installed, but still reading no fuel pressure. The only time it reads that it has pressure is when I manually fill the bowls through the site plug, and it runs fine until the fuel from the bowls run dry. Your help is GREATLY appreciated. Dave
dykstra is offline
Old 08-19-2006 | 11:52 AM
Default Re: 525SC fuel pump.
Fuel in that tube indicates a broken diaphram in the pump. When you replace it, it shouldn't need priming. The pump should suction fine without priming.
Is it a mark 4 engine? If so, did you drop the pump rod out of the block?
If it has the water pump mounted pump, was there any damage?
BTW, fuel will also contaminate the oil when a diaphram breaks, so change it.
Gary
rdoactive is offline
Old 08-19-2006 | 01:52 PM
dykstra's Avatar
It is a 1996 525SC that has the fuel pump connected to the seawater pump. I am wondering if I have to fill the fuel/water seperator filter will fuel also.
dykstra is offline
Old 08-19-2006 | 02:30 PM
I would fill the water sep filter with fuel. It will save a lot of starter cranking.
Griff is offline
Old 08-21-2006 | 10:01 AM
dykstra's Avatar
Thanks for all the info! Problem fixed. Dave
dykstra is offline
Old 08-21-2006 | 03:50 PM
ur2slo's Avatar
BINGO! Have the same set up on my ride.
ur2slo is offline
Old 08-21-2006 | 10:40 PM
dykstra's Avatar
dykstra is offline
dykstra's Avatar
The fuel was low also!!!!!!!!!!
dykstra is offline
BillR
11
07-29-2022 06:31 AM
alecsammy
0
09-21-2008 09:47 AM
ssilverado60
5
03-18-2007 09:54 AM
dykstra
2
08-12-2005 04:07 PM
