525efi thermostat ???? >
Old 04-07-2007 | 05:07 PM
Strip Poker 388's Avatar
Rob
Default 525efi thermostat ????
Were is the thermostat in a 525efi motor? by this pick it doesent .or did someone put a plate over it? Curious
Strip Poker 388 is offline
Old 04-07-2007 | 05:15 PM
If you look at the bottom part of the intake manifold on the left hand side of your pic toward the bottom, it goes where the oval shaped plate is being held down by two bolts.
Larry
62 Bel-Air 409
260 Eagle XP HP500EFI
2002 Corvette M6 Coupe
Bubbletop409 is offline
Old 04-08-2007 | 10:04 AM
Rob
[QUOTE=Bubbletop409;2085559]If you look at the bottom part of the intake manifold on the left hand side of your pic toward the bottom, it goes where the oval shaped plate is being held down by two bolts.
but that looks like a block off plate, no water neck?
Old 04-08-2007 | 10:54 AM
Michigan Mad Man
[QUOTE=Strip Poker 388;2086083]
Rob the 525's are closed cooled it is under the heat exchanger.
TylerCrockett is offline
Old 04-08-2007 | 12:50 PM
[QUOTE=TylerCrockett;2086126]
I stand corrected, thought it went in the same place as on my HP500.
Old 04-08-2007 | 01:06 PM
Rob
thanks
Old 04-08-2007 | 03:08 PM
Port side to be exact.
Cam-shaft is offline
Old 04-08-2007 | 07:58 PM
Rob
I need a picture for a mental pick please
outriggers
4
10-21-2008 10:16 PM
sd11856g
8
08-02-2007 11:39 AM
sonic28
7
04-10-2007 10:37 PM
nitro/max
2
09-21-2003 10:08 PM
SLINGSHOT
06-21-2002 09:20 AM
