Is there a difference between a marine and auto coil >
Old 07-12-2007 | 07:32 AM
Default Is there a difference between a marine and auto coil
Can I just go to Autozone and get an ignition coil for my 96 mercuriser 5.7L?
boomer is offline
Old 07-12-2007 | 08:05 AM
You must use a high vibration coil in a marine application. A car has rubber mounts for the engine which reduce vibration stress on coil. A boat dosen't.
Olds Eddie is offline
Old 07-12-2007 | 08:11 AM
The T bolt ignition is supposed to use a "special" $40 coil.
I bought a $10 GM, external resistor coil at a car patrts store and it's worked fine for years.
rdoactive is offline
Old 07-12-2007 | 09:51 AM
I got a pair of the high output high zoot chrome coils from Parts Source (Canadian version of Auto Zone)a few yrs back for my carb 350s with T Bolt ignition......no probs
wondered the same thing as you at the time but the ones I took out sure looked like standard automotive stuff to me.
pullmytrigger is offline
Old 07-12-2007 | 10:19 AM
Ted G's Avatar
The coil is hard mounted to the engine, no rubber mount. A coil is a coil, is a coil. Although I prefer Accel stuff due to good insulator plastic.
www.cbpba.com
Ted G is offline
rexone
New Products and Member Discounts
26
03-21-2009 06:56 AM
gettin wet
Do It Yourself, Boating on a Budget
3
06-20-2008 08:22 PM
MnHowardCat
2
04-23-2006 09:13 PM
GeeterB
1
04-30-2003 01:54 PM
strapman
4
01-25-2002 08:17 PM
