700SCI Questions >
700SCI Questions
700SCI Questions
Old 05-23-2008 | 01:49 PM
  #41
Whipple Charged's Avatar
Originally Posted by inknppr
I took my boat out yesterday for the first time 08 39 with 700's NXT's.
The boat had no problems getting on plane. In fact this boat gets on plane faster than my 38 with 525's. There was no lag time. I was very happy with the way the boat got on plane.
It's based off of the throttle you give it. Below 2500rpm, if you go past 50% throttle (approx) then there will be no more power available, so if your boat pops on plane with say 40% throttle, then you would hardly notice, but there is in fact a almost zero boost below 2500rpm. Problem most have with the setup is in propping, with a low rpm limit (5400rpm), to achieve max speed, you normally have to run a large pitch, which requires more power at low rpms.
Dustin
Whipple Charged is offline
Old 05-27-2008 | 11:48 AM
  #42
Originally Posted by QWKRN U
wonderful drive by wire technology. Its the tourque management software taking over. Once some of the tuners figure out how to crack the ecm's Id expect him to be very happy with those.
its cracked !
look here
http://www.offshoreonly.com/forums/s...d.php?t=187581
pokerrunboats is offline
Old 06-02-2008 | 08:54 AM
  #43
Originally Posted by pokerrunboats
Thats awsome. Now if I could only make these 496's transform into 600's....
QWKRN U is offline
Old 06-06-2008 | 06:31 AM
  #44
Thats as easy as transforming 65000 US $ into ZERO
aTX427
71
08-01-2011 07:09 PM
PowerboatsNW
Activator
3
05-04-2008 04:41 PM
Maximus
08-02-2007 05:00 PM
tgersx
07-12-2007 08:43 PM
ActiveThunder
Active Thunder
32
12-31-2006 06:48 PM
