drive shower? >
drive shower?
drive shower?
Old 02-18-2002 | 05:27 PM
crmax's Avatar
Default drive shower?
are drive showers worth it on a boat that will never see over 70mph?
crmax is offline
Old 02-18-2002 | 05:40 PM
Shooter's Avatar
Charter Member #300
The big stainless IMCOs sure look cool!
Shooter is offline
Old 02-18-2002 | 05:42 PM
blue thunder's Avatar
I would have the same question but for boats that will see over 70 mph.
BT
blue thunder is offline
Old 02-18-2002 | 06:00 PM
Your drive will benefit from the shower by lowering the operating temps. Your boat may not exceed 70 mph but your drive may be working as hard as it can to push you to whatever speed your seeing
I saw somebody has Simrek showers for sale on eBay cheap. Try these links.
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1805487261
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1805487937
Holy Smokes is offline
Old 02-19-2002 | 01:38 AM
SteveDavid's Avatar
Charter Member #1093
crmax,
It's the load on the drive that blows them, not the speed directly. As to who makes the best drive shower, there's a a reasonable debate on which one really works best. I'm currently using the Simreks and find they dispense more water ragardless of speed or trim angle over the other current external designs. Probably the most efficient is the B max drive system which uses the drive intake water to internally cool the drive.
In most every drive blow up however, it wasn't the lack of a drive shower, but the heavy throttle that caused the mayhem. The shower didn't get the first drop on the drive before it was too late Over time is where the cooler running temps. will perform their "insurance" and keep the outdrive alive.
Take care,
Steve
SteveDavid is offline
Old 02-19-2002 | 08:09 PM
Mack312
Cut down on the white chalk build-up on the B 1's
Old 02-19-2002 | 08:16 PM
formula31's Avatar
Pretty cheap insurance and logical. I use them. It doesnt mean you wont blow up a drive but it cant hurt and probably does help.
formula31 is offline
Old 02-19-2002 | 09:07 PM
Vinny P's Avatar
I hate the winter!!
Absolutely worth it. The cheapest insurance you can get.
Vinny P is offline
Old 02-19-2002 | 09:34 PM
crmax's Avatar
formula31, I didnt forget about the humming bird I just have to find time to drop it off email me your home address and Ill drop it off there if you want
crmax is offline
jns
Nordic
3
08-19-2008 06:27 AM
DiamondPerformance
New Products and Member Discounts
3
05-31-2007 08:36 PM
Mikey Likes It
12-10-2005 09:36 PM
Superbabi
Superboat
15
11-24-2005 05:05 AM
502SCS
35
02-20-2005 04:41 PM
