496 impeller housing >
Old 05-06-2008 | 12:29 AM
Default 496 impeller housing
Just took apart the seawater pump,and the pump cover has some wear on it,its brass,not to deep,maybe 030 inch,is this normal,what can be done?Thanks
apexer is offline
Old 05-06-2008 | 06:33 AM
Pwrbt33's Avatar
Its normal. I usually try and belt sand the rear cover to help get a new surface, theres not much you can do with the inside of the housing besides order a new on that comes with an impeller. Someone was talking about a stainless insert to put into these pumps but I cant remember who it was.
Pwrbt33 is offline
Old 05-06-2008 | 07:44 AM
BL6
Do a search back on old posts for 496 impeller housings.
A firm in Lake Havasu sells inserts that worked very well for me.
BL6 is offline
Old 05-07-2008 | 07:17 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Some light wear is normal, however if the gouges are deep enough it will damage the new impeller & it may not work at all.. The 496 pump housings dont seem to last as long as the older stuff did.. I liked the older ones with the replacable wear plates and rear housing.. then you had no worries.. jamie / Lakeside Restorations
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
techman
15
04-18-2008 06:02 PM
jonyb
TN Powerboat Club
0
07-30-2007 09:16 PM
Cattitude
3
04-08-2007 11:14 PM
Bolts21
8
05-15-2006 09:49 AM
Nordicflame
4
03-04-2004 10:21 AM
