bottom staining >
bottom staining
bottom staining
Old 06-02-2008 | 08:39 PM
The Works from the Dollar Store $1.00 for 32oz. no pun but it works.
formula 382 sr-1 is offline
Old 06-02-2008 | 08:51 PM
rbtnt's Avatar
Some of the cleaners like "The Works" will remove the stains, but as others have said, they will return sooner the next time.
Here is a thread from the past that talks about a pool cleaner called Ringo. I have used it with great results.
http://www.offshoreonly.com/forums/s...ad.php?t=77542
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 06-02-2008 | 08:57 PM
t500hps's Avatar
21 and 42 footers
I've used On/off for years but cut it about 30% to 70% water. Once used, the hull WILL stain faster. I try to clean the bottom very well in the fall then put a coat of wax on the bottom sometime during the winter.....by mid-summer the stains are back so I'll on/off it again and get it waxed that same week before going out.....without that coat of wax it stains BAD!!!
Gelcoat has tiny hole that the dirty water sits in, wax just fills those holes and keeps the bottom clean until the wax wears off.
t500hps is offline
Old 06-02-2008 | 09:01 PM
Originally Posted by bcfountain
i think the gel-coat wears or gets porious overtime.
I agree. I don't think there is anything appreciably different in new gel coat. I agree that old gel gets porus, just like decks and hull sides, the bottom gets old and chaulky.
I've been considering sanding and buffing the bottom. However, it's a huge and ugly job. We've done small areas like the transom below the water line and damn if it doesn't stay cleaner longer than the rest of the hull. I really think that's the answer.
ThirdBird is offline
Old 06-02-2008 | 11:10 PM
Rebel_Heart's Avatar
I get the yellow stains off once a year with muratic acid. And, I'm never in the water more than an afternoon at a time.
Rebel_Heart is offline
Old 06-02-2008 | 11:27 PM
I agree if the bottom is polished it will stain less. I have noticed people use a scotch brite pad with the cleaner. BAD move it makes micro scratches and it will stain worse next time.
Just like a caulky deck holds stains the gel on the the bottom as it ages will hold it too. It just doesn't fade from uv and appears in better condition then it is. Its not the chemicals its the porosity of the gelcoat that comes from age and often sratches from scotch brite pads.
MOBILEMERCMAN is offline
Old 06-03-2008 | 12:07 AM
ruined part of my black gelcoat, do NOT let that stuff drive, even for a second!
waterboy222 is offline
Old 06-03-2008 | 05:46 AM
Thanx Guys Glad To Hear Im Not The Only One Dealing With This Headache!!
Baddogg is offline
Old 06-03-2008 | 07:25 AM
BillR's Avatar
OSO Moderator
Stop using acid based cleaners (on-off, FSR). It also attacks your gel coat. THAT is why the stain keeps coming back faster and faster. The more you acid clean - the more damage done - the faster and darker it stains.
If you can't apply it w/ bare hands and also be fume free - it is acid based. If it is at you local marine store - acid based.
You can either clear coat the bottom- no more stain or use Ringo and remove the stain while leaving your gel coat intact.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 06-03-2008 | 08:38 AM
mjb
RINGO...RINGO...RINGO....the miracle cure- so they say. This issue was beat to death in a previous thread. The problem is..at least for me...that after a lot of searching, I can't find any pool cleaner dealers who sell it. Most have not even heard of it. Apparently there is a member of OSO that sells it out of his garage?? If it's so good, why is it so hard to find?? I would love to try it if I could buy it from an established dealer...not from a private party....and my appologies up front if my info is wrong.
mjb is offline
