500hp carbed >
500hp carbed
500hp carbed
Old 07-18-2008 | 09:04 PM
baja36ft's Avatar
Originally Posted by ubet28
So should i run a 23 mirage plus with this motor labbed or not labbed? Any advice would be great motor should be here the 22nd so i need to get the prop situation worked out.
if you are putting the 500 in your gonna need a 4 blade...
i say a bravo 24,26 pitch or maybe try a hydromotive prop.
baja36ft is offline
Old 07-18-2008 | 09:26 PM
Ok Thanks
ubet28 is offline
Old 07-19-2008 | 07:10 AM
Thunderstruck's Avatar
My rough costs:
Anodized AFR Heads ss intake, inconel exh, titanium retainers, springs, cups, head studs $3,000/set (I bought the bare 305cc AFRs with the CNC chamber, RMBuilder selected the components.)
Custom cam $450 per side (RM Builder)
Morel Lifters $450 (RM Builder)
Intake pushrods ~$100
HI6M Ignition $250 plus $75 for wire/mounts etc each side
Edelbrock Victor Jr. Intake $220 plus $75 for powdercoat
Carb $900 each
1" spacer ($20 each)
Gaskets, RTV, Shop supplies, Beer $500 per motor
Dyno $300 cash (2 sessions) so $600
Freshen motor (clean, hone, inspect block, polish crank, Make rod ends round, rings, bearings, assemble heads and short block $1,000 per at a machine shop)
Closed loop cooling for aluminum heads ($1100 per)
I pulled the motors, assembled the long block, took to dyno twice, did the tech work at the dyno, installed in boat, etc.
I did not have to modify my stock 500 HP fuel system.
Like I said, not cheap and I did all the grunt work. Hope this helps.
Long time cult member.
Thunderstruck is offline
Old 07-19-2008 | 07:14 AM
Oh, BTW I changed bolts to stainless where it made sense, ARP intake, exhaust, some of the bell housing, some of the motor mount, all bracket bolts, oil pan bolts. Probably $200/motor.
I also did not have to modify the oil cooler or lines.
Fuel and oil system add another $1000 per.
Don't underestimate how expensive these projects can be, there are a LOT of hidden costs in a project like this.
Old 07-19-2008 | 08:50 AM
Hey thunderstruck thanks for the list that helps out. Now that i can see some numbers i no what i am getting into. See i am trying to decide if i wanna do a blower or motor work?
It looks to be relatively close in price maybe a little more for the heads and cam. But if the gains are close to the same i will just do the motor work. and keep reliability.
Does any one have any input i on blower or do the heads and cam?
Once again thanks to every one for chiming in you guys here at offshore have been a huge help. Jeramy
ubet28 is offline
Old 07-19-2008 | 08:53 AM
Where are you guys finding the AFR heads that are anodized?
And would you still need the closed cooling since they are anodized?
niceguy is offline
Old 07-19-2008 | 09:00 AM
TP Marine, AFR anodized heads, use to be 10% discount for OSS members. Might want to call. RM Builder is also an AFR dealer and can get the same.
http://www.tpmarine.com/index.asp?Pa...OD&ProdID=1383
daveintexas is offline
Old 08-10-2008 | 12:03 AM
Still in need of some help with prop should i try 24 or 26 pitch? for 1998 baja with bravo 1 and a 500hp. If anyone can help me that would be great.
ubet28 is offline
ubet28
1
10-20-2008 04:10 PM
speediseverything
11
09-22-2008 11:49 AM
ubet28
9
07-07-2008 06:54 AM
Croozin2
7
08-15-2007 11:55 AM
outlawinil
13
06-18-2003 03:21 PM
