Under Hatch Mirror,What backing do I need? >
Old 04-28-2009 | 04:36 PM
5200 takes way to long to set, won't ever come off but takes weeks to totally set
ezstriper is offline
Old 04-28-2009 | 08:54 PM
Audiofn's Avatar
Charter Member #232
Formula uses screws with platic shim deals to hold the mirror on. I can try and take a picture this weekend if you want.
Put your best foot forward!
Audiofn is offline
Old 04-28-2009 | 08:57 PM
GO4BROKE's Avatar
I used 3m emblem adhesive 2 sided tape on my 1997 31 sonic, 12 years, mirror is still there. Lots of rough water on Lake Ontario. But hatch is flat on the back side, I don't know about a curved surface.
[img][/img]
GO4BROKE is offline
Old 04-28-2009 | 09:59 PM
johnnyboatman's Avatar
the red 5200 sets up fast the blue tube takes a week.
johnnyboatman is offline
Old 04-29-2009 | 09:42 AM
Steel Outlawed's Avatar
I used the 3m automotive double sided tape and mine has been in place now for 4 years.
Steel Outlawed is offline
Old 04-29-2009 | 06:21 PM
Strip Poker 388's Avatar
Rob
Originally Posted by Audiofn
Formula uses screws with plastic shim deals to hold the mirror on. I can try and take a picture this weekend if you want.
Jon please,is it just a spacer? does it have a backing on it?
I talked to some places that sold starboard and they said that glue doesn't stick to starboard very good,
I plan on using the backing to glue the mirror to ,then bolt the mirror and backing to the bottom of the hatch, the hatch you cant screw to it, its foam in-cased ,screw just pulls out. the factory used the Philip's machine screw and a stainless t nut on the top side, the hatch cover is attached the same way,the mirror will over hang the hatch screws they would dig into the back of the mirror.
I would think the mirror would be wavy looking with out the backing.ie using 2 sided tape? would be alot easier
the mirror on each side is 32x68
ya can see the bolt holes in the hatch pick
Attached Thumbnails Under Hatch Mirror,What backing do I need?-hustler-hatch-pin-001-large-medium-.jpg
Strip Poker 388 is offline
Old 04-30-2009 | 05:13 PM
crayolacrazy's Avatar
I had mine made of stainless and used screws and 3m tape ...................... nice video
crayolacrazy is offline
