Starter Question ..... >
Old 04-02-2002 | 03:52 PM
CheckmateF1's Avatar
Charter Member #355
Iggy, Donzi is right. Two solenoids. And as he stated the small one up on the motor harness is called the "slave".
Eric
CheckmateF1 is offline
Old 04-02-2002 | 05:12 PM
Iggy's Avatar
Yeah guys, you were right. I checked the schematic and low and behold I do have two solenoids. Silly me.
Just got back in from testing it out and sure enough the slave solenoid is bad. I jumped it with a pair of pliers and she cranked over immediately. Tried the keyswitch and "click!", jumped it again and she cranks.
Thank you all, now I know what to replace.
Gotta love this place.
Iggy is offline
Old 04-03-2002 | 11:18 AM
MnFastBoat's Avatar
Charter Member#157
Question
This sounds similar to what i have had happen
From time to time I am not able to get the motors started.
I would just get one 'click' when turning the key.
It first started wit hthe port motor. Then the starboard over teh course of the year.
It does not do it everytime. Seems to happen most when hot.
I could hit the key several times and then it would start.
Seems to me tho' that I was thinking it was the starter or even the starter soleniod. The bilge did have water in it one time. Fresh. Ever since then it has happened.
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 04-03-2002 | 12:58 PM
Cool
Another item to look at is the ignition switch. Check voltage at switch and solonoid. Mine was soooo full of saltwater once (installed upside down with drain hole on top ) the engine would not turn OFF . It did not work very well after that.
RickR is offline
dyno
36
09-07-2006 09:00 PM
tmthunder
1
05-28-2004 11:48 AM
THRILLSEEKER
3
08-19-2003 09:29 PM
Air Dog
2
05-06-2003 09:10 AM
blue thunder
16
01-17-2002 09:45 AM
