MSD coils and ballist resistors >
Old 04-06-2002 | 03:41 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default MSD coils and ballist resistors
Bought the MSD Hi-Vibration Balster coil to replace my stock one. Do I need a ballist with this one or is it only for distribs that have points? All other ignition is the stock Merc.
US1 Fountain is offline
Old 04-06-2002 | 03:50 PM
CheckmateF1's Avatar
Charter Member #355
Jerry, I think you are correct. The resistor should be for points only. I have a MSD Blaster coil on my 500 with all else stock Merc. Worked great last season and I'll put it on this season as soon as the motor gets back here.
Eric
CheckmateF1 is offline
Old 04-06-2002 | 11:55 PM
ballast resisters are only needed for points. if it was converted from points to electronic the resister has to be removed to get at least 12 volts to the coil or the ignition module will be damaged.
not all had ballast resisters though. some had resisters wires to lower the voltage after startup so the points wouldn't burn up. same thing though, just find it and cut it out or replace the wire.
Fran
excaleagle42 is offline
Old 04-07-2002 | 12:55 AM
puder's Avatar
speel chekk this fokker!
brad perry was nice enough to send me his spare blaster coil and i have an MSD box. I am addign this to my setup this year. I am running a thunderbolt 4 ignition am i goignt o need one of these ballast resistors?
Pardon me, while I whip this out!
puder is offline
Old 04-07-2002 | 01:01 AM
kaamacat's Avatar
Puder.......Nope. Not unless you are using a actual point set. With that you have the ballast resistor (or wire) inline to the (+) on the coil, which drops the 12v down to about 7voltish. (otherwise you would burn out the point contacts).
kaamacat is offline
Old 04-07-2002 | 03:29 AM
Ginger or Mary Ann?
Thanks guys! So no resistor.
Also think I found my problem of why my motor missed out under load 2 weeks ago while on the dyno. Apparently over the winter while the motor was apart and the distrib was laying on the floor, some oil must have ran up the shaft, into the cap and into the pickup. Rotor had an oil film on it. Oh well,...... new cap, rotor, coil and wires. Was all original '94 anyway. So now good to go!
Jerry
Old 04-07-2002 | 03:47 AM
puder's Avatar
i gotcha! cool
puder is offline
pkspx
61
08-20-2015 09:06 AM
ctadams21
3
03-17-2007 01:47 PM
MrCIG
14
06-01-2006 09:27 AM
kennyo
4
03-27-2004 12:19 AM
Aqua-Holic
01-17-2003 06:24 AM
