cost to polish imco lower? >
Old 06-04-2010, 11:46 PM
Chris
CB-BLR's Avatar
Originally Posted by Smitty
I agree that polishing the lower will actually increase drag and loss of speed. I have sanded/scuffed the bottom of my boat to make it rough and it has actually gained speed at all rpms.
When I used to build racing jetski's, we would true the bottom of the hull, and then use a orbital sander with 60 grit paper to roughen up the entire bottom of the ski... it was usually good for 1-3 mph on a 70 mph ski.
Chris
CB-BLR is offline
Old 06-04-2010, 11:55 PM
if you want it polished... sand it with up to about 800 or 1000 grit and then finish it off with heavy duty rubbing compound on a lambs wool pad. finally etch the shiny surface with por-15 metal prep and shoot it in glisten clear coat. it'll stay shiny and the paint will stick as well as any paint sticks to an outdrive. I've done mag wheels, my polished imco manifolds, and a lot of other things this way...
for rouging it up / performance wise, i understand that 400 grit is about the bvest range based on the typical speeds and surface characteristics of water... you want "turbulent flow" rather "than laminar flow"....
wtfo is offline
Old 06-05-2010, 02:08 AM
Received 1,821 Likes on 907 Posts
Originally Posted by Smoothsix
just wipe on and wipe off ?
Spray it on with a pump garden sprayer and then rinse it very well. The SOS pads will work also, just a little more work.
Griff is offline
Old 06-05-2010, 05:22 PM
Rob
Strip Poker 388's Avatar
but they look good when there polished,Now a waste of time is polishing the anoeds
The Imco foots are alot easier to polish than the B Max!!!
Attached Thumbnails cost to polish imco lower?-boat-car-show-jan-2010-062-large-.jpg   cost to polish imco lower?-outdrive-polished-9-16-09-026-large-.jpg   cost to polish imco lower?-outdrive-polished-9-16-09-056-large-.jpg
Strip Poker 388 is offline
Old 06-24-2010, 07:48 AM
Those look very very nice! Did you notice any speed loose.
Wes
wnelles is offline
Old 06-24-2010, 08:34 AM
I just noticed this thread. Over the last few days I removed the paint from my bravo lower with a DA and rotory tool. Smoothed out all the imperfections, rounded off corners, then wet sanded with 600. I would have used 400 but I already had the 600. I like the look of the brushed alluminum vs painted. I am hoping to pick up a MPH or even a 1/2 MPH.
jeffswav is offline
Old 06-24-2010, 08:56 AM
LAriverratt's Avatar
I use aluminum brightener (Nu-HUll boat cleaner)....i use it on the gel coat to take off scum lines and on lowers to shine them up. I wont hurt your boat, trailer, paint, or concrete. dont let it sit on hot surfaces of aluminum that are polished it'll turn in white and then you have polish again!!!!
LAriverratt is offline
Old 06-24-2010, 09:45 AM
For the satin look, can the 400grit trick be done with a welded nosecone or will the weld lines still show thru???
fantastixvoyage is offline
Old 06-24-2010, 11:10 AM
Rob
Wes
none that I can tell.
