what rpms should i run??? 540ci NA.....
#42
Could you explain this to me? I see that your valves will be closer to the piston but the lift and rocker ratio is still the same. The mechanics that lift the valve are the same.
#43
Those cams are awful. They have less duration and lift than a 415hp 502 efi. Most rv cams have more lift and duration. A good cam for stock rectangular port heads is the Crane 651. It is 244 int. / 256ex. duration @ .050, .630 / .630 lift. this cam will make 575-600 hp and rev to 5400-5600. For any more hp, you will need aftermarket heads.
#44
You will appreciate the new castings. This will be the Marine/Street Strip head that he has wanted to cast for years. He has a couple heads out there on some boats and a couple on some weekend drag cars. He finally got some poured a few weeks back, they are at Dart getting the machine work finished now. Hopefully he will get them back before Christmas and I will post some pics and info.
#45
You are correct, what I meant was that he will loose the ability to put in a higher lifting cam because there will not be as much clearance.
#47
The piston to valve clearence with those pistons is quite large. Easily enough for any cam you would want in a marine engine. To answer the original question, I bet the hp peak would be 4600 using the parts specified. And I would guess that it makes about 450 hp but about 700 ft.lbs. of torque.
#48
#49
