All of a sudden 3/4 throttle and hitting rev limiter. >
Old 01-28-2011 | 01:05 PM
Blue by You's Avatar
FIERCE ALLEGIANCE
Default All of a sudden 3/4 throttle and hitting rev limiter.
Friend of mine has a 25 outlaw with a 496HO stock setup. On a normal day you can push the throttles forward and run all day long. All of a sudden he said he started to hit the rev limiter which never had happened before. Now the boat can only get to the 3/4 throttle before hitting the limiter. RPM's and speeds are all normal.
Was told it wasn't linkage or coupler.
Prop is in good shape. No signs of dings, nicks?
Any ideas? Could props blades have warped, etc to a point where it can increase RPM's?
Blue by You is offline
Old 01-28-2011 | 01:11 PM
If the prop has a rubber coupler, they can spin as the load increases. This could the reason for the same speed but more RPM.
BenPerfected is offline
Old 01-28-2011 | 01:31 PM
blue thunder's Avatar
Sounds to me like a valve train issue, maybe broken spring(s).
blue thunder is offline
Old 01-28-2011 | 02:06 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
How can he be hitting the rev limited now even though the RPMs are the same?
Are we just talking throttle lever position like when you run in cooler temps, motor runs better?
US1 Fountain is offline
Old 01-28-2011 | 04:12 PM
the RPMs have to be increasing, otherwise how could it possibly be hitting the rev limiter?
I agree with the prop hub possibly spinning, although they usually will spin when getting on plane if they are going bad.
Philm is offline
Old 01-28-2011 | 04:25 PM
mark the prop and hub and see if the marks stay aligned. Coupler is a little harder to check but I've been told you will smell burned rubber if it is slipping.
thirdchildhood is offline
Old 01-28-2011 | 04:38 PM
I interpret his post as the rpm and speed are in-line but low due to what seems like rev limiter action.
Old 01-28-2011 | 07:30 PM
Too Stroked's Avatar
That's right. Is he actually hitting the rev limiter or is the motor breaking up - which sounds like hitting the limiter?
Too Stroked is offline
Old 01-28-2011 | 07:34 PM
Maybe guardian mode. Good clarification, not prop hub or coupler then. The engine gurus here will know .
Old 01-28-2011 | 07:40 PM
DollaBill's Avatar
OSO OG
correct. check that first. You can do it yourself and it's an inexpensive repair if necc. go from there
DollaBill is offline
