Engine paint question. >
Old 12-27-2013 | 09:52 AM
I use HOK for their "different" color selections.
Young Performance is offline
Old 12-27-2013 | 11:56 AM
Originally Posted by Young Performance
I have used Imron. The problem that I found is that it's a little too hard and some want to crack eventually. The other issue is that you don't have the benefit of clear. You can use it if you want. but it doesn't require it. The newer high solid clears will give you a ton more protection than a single stage Imron.
The key is using good products. If you use an acid etch primer, be sure to remove ALL paint first. If not, you will be sorry. The acid will eat into the remaining paint and lift it. Once it lifts, it all comes off. Acid etch primer is awesome....you just have to use it correctly. You can also use an epoxy primer is you aren't going to strip them. You don't have to strip them if they are in good shape. You can just scuff them and shoot. Blend in any chips so they don't show though, if it has any.
I put on a bunch of material. I'll shoot 2-3 coats of primer, 3 coats of color, and 3 coats of clear. Good materials are expensive though. On average, I'll spend at least 200-300 per engine in materials only. I shoot a lot of House of Kolor, which runs about $120 a quart. I recently shot some Sikkens that was over $200/quart, along with a pearl base maker that was almost $300/quart. I had over $1000 in materials alone. I was matching a color from TAOD and wanted to stick with the same stuff.
Give me a shout I can help. I'm certainly no paint expert, but I've painted a few engines. Most body shop supply stores are more than willing to help. That's where I learned a lot of what I know about paints.
Eddie
I think I am leaning towards the epoxy primer, and scuffing the current finish. They are in really nice shape as is . I think I am just going to go with a quality automotive paint/clear combo. Don't need it to be a show piece, lets face it, its a vintage B&M blower.
Lots of good info on this thread, thanks guys! BTW, this is the engine that got me horny about doing this
Attached Thumbnails Engine paint question.-whitewhipple.jpg   Engine paint question.-whitewhipple1.jpg
MILD THUNDER is offline
Old 12-27-2013 | 12:11 PM
That white combo is kick a$$.
mptrimshop is offline
Old 12-27-2013 | 04:21 PM
I figured that when you said that you wanted to go white on the blower. I assumed that is where you got the idea.
Good luck with it.
Eddie
Old 12-27-2013 | 06:33 PM
Do those have a matte finish to them.... If not I think that would look great too. If ya loom at the blowers then the valve covers... The covers have a different look.
Old 12-27-2013 | 07:39 PM
Would powder coat be an option?
Sledge Hammer is offline
Old 12-27-2013 | 07:51 PM
tcwcar's Avatar
Joe
Thunder always used BC/CC on all the motors I painted, restored classic cars, custom cars, boats...used HOC, DuPont, PPG, even Nason, never had a problem....here's a few I painted [ATTACH=CONFIG]515300[/ATTACH][ATTACH=CONFIG]515301[/ATTACH][ATTACH=CONFIG]515302[/ATTACH][ATTACH=CONFIG]515303[/ATTACH][ATTACH=CONFIG]515304[/ATTACH]
Attached Thumbnails Engine paint question.-p6220639.jpg   Engine paint question.-p6220641.jpg   Engine paint question.-dsc_0050.jpg
tcwcar is offline
Old 12-27-2013 | 08:22 PM
Looks great man. Whats your preferred choice of the ones you mentioned here?
Old 12-27-2013 | 09:40 PM
tcwcar's Avatar
Joe
PPG base coat, they also have a custom color line called Vibrance, the clear is PPG 2021 or 4000
tcwcar is offline
Old 12-27-2013 | 11:07 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
That's pretty impressive Joe . Beautiful work . Did you used to come to Raystown with a boat named " Shake-N-Bake " ?
the deep is offline
