Cam shaft numbers >
Cam shaft numbers
Cam shaft numbers
Old 01-30-2014 | 08:31 PM
  #171
Not sure he realizes what a 540 is. Or the fact everything he already bought would be useless
Unlimited jd is offline
Old 01-30-2014 | 08:37 PM
  #172
Originally Posted by Eliminatorshane
Soo I just want to chime in . Mike told me about the 731 cam and he got kinda crucified but I'm seeing I guess that it is a good off the shelf cam?? While everyone's fired up here I'm just curious what is the best centerline to go with on a cam to not have reversion? And since you guys have built engines should I do my 502 block to 540 or just get a dart. I will be running about 5-7 pounds of boost and now that my butt stopped hurting from buying the crank ,rods and pistons I want it to be ok.......
Not a big deal to make a 540 out of your 502 block but the block leaves alot to be desired. The oil system in a Dart block is much better. As far as a cam centerline it depends when you want the torque to come in and how much your gonna spin the motor. If your question was worded wrong I would go with a 114.
Black Baja is offline
Old 01-30-2014 | 08:38 PM
  #173
No red I have a 502 block. Sitting at the machine shop. I bought a magnum Xl 4.25 stroke ,Oliver rods 6.385, and je pistons .30 over .. 4.50 bore. I have a 8-71 littlefield blower and was just trying to see what opinions on the block I have vs dart block that's all. I also just wanted to know about reversion and when it starts on a cam and that's all. Like I said before my first high performance boat.
Eliminatorshane is offline
Old 01-30-2014 | 08:42 PM
  #174
And haxby it was a error what I wrote. That's all. I bought everything for a 540 but have a 502 gen 6 block that I'm putting in a Daytona.
Old 01-30-2014 | 08:45 PM
  #175
You spent the money on some good parts. Minus well get a nice block to put them in. Sorry I can't help you on reversion cams after my first milkshake I've always ran dry exhaust.
Old 01-30-2014 | 08:46 PM
  #176
How much money you want to spend? What heads are you going to use? what RPM you going to spin to? what boat is it going in? 731 is a really mild cam for a NA 540. Even a 741 in a 540 is a less than you need. I don't do blowers, so the others will need to tell you that. The 502 block is fine for a 540. Unless you have $$$$ to burn you don't need a Dart block.
Zone 5 is offline
Old 01-30-2014 | 08:48 PM
  #177
Gotcha, that makes more sense. If you've already got the gen6 block and it sonic checks ok, (they're usually pretty thick) then id run it.
HaxbySpeed is offline
Old 01-30-2014 | 08:52 PM
  #178
Black my question is worded wrong. I was just curious when reversion would kick in or is it manifold or header specific. Also haxby and red you got to understand this is my first big engine boat. In cars I never worried about sucking water. I'm not a ****in idiot go to June 2001 super chevy mag and the Malibu they did a piece on is mine runs 7.73 181 mph and I drive it to sonic every other Friday. Except for engine I did everything else including stitching my own interior inc. the leather wrapped 14 point funny car caged bars. Go to Barrett Jackson last year loom up 69 chevy camaro yenko. Yep I did it but didn't own it. It sold for 175,000 moral of the story is I'm not ****in stupid.
Old 01-30-2014 | 08:59 PM
  #179
Money isn't the issue. It's a how much am I gonna have in a boat that will be sold in a year issue. But I don't want someone else taking on a problem that could have been rectified. If it's a good block for say. 750 - 800 hp than cool. I got ****ed from the beginning on the boat and I want it to be right. I want it built like I'm gonna keep it then we sell. As you can see from all other posts I sold the gauges. Old rotating assembly. Etc,etc. this year before summer will be all mechanical and this winter we will repaint with kickass graphics and sell in 2015 with new interior also. Some say its fine some say dart. Just was wondering.
  #180
Wow that's impressive. I fixed a Camaro that sold at Barrett Jackson for 140000 and almost burnt to the ground cause someone Mickey moused the wiring.
